Author Topic: Front muguard mounting question  (Read 883 times)
Offline sye
« on: October 18, 2018, 04:42:04 PM »
I'm a bit confused and either have the wrong front mudguard and forks on my 500 K1 or DSS have made a mistake? The bracket and stay mounts on my bike all use M6 bolts with the front brake mount using an M8. On the DSS side they list a 750 K2 mudguard as a replacement and state that it uses an M10 instead of M8 mounts on one side and to consider using washers.
Mine uses all M6 for mounting is this correct or do I have the front end off a C90?  :-\
Offline SteveW
Re: Front muguard mounting question
« Reply #1 on: October 18, 2018, 05:27:10 PM »
Mine are M6, 74 550 K0
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #2 on: October 18, 2018, 05:46:29 PM »
They mean that the holes are bigger so you need to use a washer
« Reply #3 on: October 18, 2018, 06:09:32 PM »
The Mudguard is not original to your bike. You can use a rubber mount PN 40513 310 000 and a tophat washer PN 40514 310 000 or as Bryan said, a washer  ;)
Offline Seabeowner
« Reply #4 on: October 19, 2018, 09:44:53 AM »
500s had the 6mm clearance hole. 550s had the guard rubber mounted with the larger holes in the stays and one side of the bracket. The rubber mounts and tophat washers will set you back over £40 at DSS!
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline AndyH
  • I'm privileged to be a
« Reply #5 on: October 19, 2018, 11:01:35 AM »
M6 is correct.
As Bryan and Trig have said, just use washers.  In restoring my 500K1 (AUS) I bought the DSS mudguard as well, and used suitable washers.
Andy
1971 CB750K1
1972 CB500 Four K1 (SOLD)
1978 Suzuki GS750E
Previously....
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Offline sye
« Reply #6 on: October 19, 2018, 02:41:11 PM »
Thanks everyone, washers seem to be the answer.
Whilst I'm here, there's a guy on Fleebay who is based in Vietnam and sells mudguard copies. Anyone used him?
« Reply #7 on: October 19, 2018, 02:59:04 PM »
He's well known.
Ask Ash.
2022 Tiger Sport 660
Offline sye
« Reply #8 on: October 20, 2018, 10:39:18 AM »
Now then, it seems that CB550 front mudguards are still available and it certainly looks very similar. Does anyone know if they fit the 500? Different part number but sometimes it means nothing?
