Author Topic: Lets play spot the difference K6  (Read 1336 times)
« on: November 08, 2018, 11:10:12 PM »
These are both UK K6 cases,first clue 2468164 has a M6 top bolt and 2468581 has a M8 top bolt. How many other differences can you spot  on cases only 417 apart  :o
Offline Woodside
Re: Lets play spot the difference K6
« Reply #1 on: November 09, 2018, 07:30:14 AM »
That small casting to the left of where the starter sits looks different in the pics...
Online Rozabikes Tim
« Reply #2 on: November 09, 2018, 07:43:31 AM »
The long numbers in the square box below the starter housing look different to me ;D
« Reply #3 on: November 09, 2018, 08:09:30 AM »
The length of the bolt hole to the left of the starter housing is longer  ;D
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
« Reply #4 on: November 09, 2018, 08:10:02 AM »
D shaped casting on top one where oil pressure switch goes
More pronounced rib on long oil gallery on top one
Can't see casting with hole at bottom RHS on top one but could be photo angle.
Surface casting surface finish sh*ttier on one than the other...but could be one was more corrosion weathered than the other.
Casting different ...centre of three holes below VIN pad
Casting hole below LHS of starter looks beefier on top one and hole not central on bottom one
Can't see hole left of starter on one but probably photo angle
Someone forgot to remove all of the residue of the base gasket on the top one prior to painting  ;D ;D
« Last Edit: November 09, 2018, 08:40:23 AM by AshimotoK0 »
« Reply #5 on: November 09, 2018, 08:11:52 AM »
The casting around the oil pressure switch is different  ;D
Honda CB400 4
Honda CB750 UK K1
« Reply #6 on: November 09, 2018, 08:12:20 AM »
Dam beet me to it Ash >:(
Honda CB400 4
Honda CB750 UK K1
« Reply #7 on: November 09, 2018, 08:24:20 AM »
Oi, scrapping old gaskets off is my department, 😀😀😀 Its discoloration of the alloy, see it quite often on some of these old engines. You don't really think Graham would let me get away with sub standard work do you 😂😂😂
« Reply #8 on: November 09, 2018, 08:26:31 AM »
It was a joke  ;D ;D ;D ;D  ...Can't blame you for 'scrapping' gaskets ..they can't be reused  ;D I know your prep is top notch.  ...What's the prize by the way ?
« Last Edit: November 09, 2018, 08:29:30 AM by AshimotoK0 »
« Reply #9 on: November 09, 2018, 08:31:57 AM »
It was a joke  ;D ;D ;D ;D  ...N't blame you for scrapping gaskets ..they can't be reused  ;D I know your prep is top notch.  ...What's the prize by the way ?
Prize, ha,  I'm sure Graham will find something appropriate 😀😀😀
« Reply #10 on: November 09, 2018, 08:35:14 AM »
Oh yea, scrapeing not scrapping (bloody spell check)
« Reply #11 on: November 09, 2018, 09:53:12 AM »
The piece of wood below the casing is in a different place on the second one.......😳. Is the piece of wood the prize? Should call it by its technical term of 'Upper crankcase assembly supporting block' and sell them on ebay😉
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline mike the bike
« Reply #12 on: November 09, 2018, 01:28:17 PM »
Scraping actually.  You drop the e before adding ing
« Reply #13 on: November 09, 2018, 01:44:54 PM »
Try telling my bloody spell check that. 😂😂😂
« Reply #14 on: November 10, 2018, 11:34:54 PM »
Only one difference, they were cast by 2 different manufactures  ;)
