Author Topic: 550K1 fork oil  (Read 555 times)
Davelu88
  • Guest
550K1 fork oil
« on: February 03, 2019, 05:47:50 PM »
Hi all, anyone know how much fork oil should be in a 550K1 and what oil to use , searching brings up varying opinions.
Online Johnwebley
Re: 550K1 fork oil
« Reply #1 on: February 03, 2019, 06:06:01 PM »
Assuming it's the same as the 500.
Try 160cc  atf oil
Davelu88
  • Guest
Re: 550K1 fork oil
« Reply #2 on: February 03, 2019, 06:08:34 PM »
Cheers John
Re: 550K1 fork oil
« Reply #3 on: February 03, 2019, 06:09:34 PM »
Or ATF
Re: 550K1 fork oil
« Reply #4 on: February 03, 2019, 06:11:12 PM »
Sorry to correct you John, it is 164.997 cc  :o and that is on a full strip and clean. If just a drain from the side bolt then totally different  ;D ;D
Davelu88
  • Guest
Re: 550K1 fork oil
« Reply #5 on: February 03, 2019, 06:14:54 PM »
Just a drain  & replace Graham , so what would that be. cheers
Re: 550K1 fork oil
« Reply #6 on: February 03, 2019, 06:39:32 PM »
It is very hard to get it correct with a drain. You can be out by 10cc on each fork but, the book says 135 to 145cc  ;)
Offline deltarider
Re: 550K1 fork oil
« Reply #7 on: February 03, 2019, 06:58:00 PM »
My CB500K2 (ED) has the same legs. I personally have best results with 140cc 7,5 weight.
Davelu88
  • Guest
Re: 550K1 fork oil
« Reply #8 on: February 03, 2019, 07:48:21 PM »
Cheers  ;D
