Author Topic: Pick this up in the morning  (Read 4952 times)
Offline Moorey
Re: Pick this up in the morning
« Reply #30 on: March 16, 2019, 07:10:55 PM »
Did your battery come back up.?
Offline MarkCR750
« Reply #31 on: March 16, 2019, 07:13:01 PM »
Thanks Phil, it’s great apart from things like poor brakes (think no brakes!), there is no tickover facility, evidently the idea was you stopped the engine by closing the throttle!, I’ve set the throttle cable to hold a tickover but have to stop the engine by stalling it on the clutch now, also trying to remember that the gears and rear brake are swapped over is a nightmare, it’s ok until you’re in a panic situation and then you’re pressing the gear lever instead of the brake, the only thing to do is ride like an 80 year old granny , that gives you time to put right what you’ve just done wrong:), charming little bike really though.
Suzuki GT250A (Nostalgia)
1977 K7 CR750 (lookalike, what of I’m not sure)
Ducati 900SS (Soul & Speed)
Ducati M900 Monster (Handling & character)
Thruxton 1200 (suits me)
James Captain 197 (pure adrenaline, i.e. no brakes!)
Sir J.Stewart.
Offline MarkCR750
« Reply #32 on: March 16, 2019, 07:16:25 PM »
Ah yes forgot to say, I’ve put it on the 12v charger several times, checking it with the multimeter so as not to overcharge, and finally today it’s holding 6+ volts so a success, thanks.
Sir J.Stewart.
Offline Moorey
« Reply #33 on: March 16, 2019, 08:06:46 PM »
A good result then.  :)
Offline MarkCR750
« Reply #34 on: March 17, 2019, 08:18:23 PM »
Yes thanks for the advice Moorey, I was about to buy one until you suggested using my 12v charger.
Sir J.Stewart.
Offline MarkCR750
« Reply #35 on: March 30, 2019, 08:50:01 PM »
I know modern bikes are very efficient etc but when it comes to maintenance this thing is ridiculously easy, remove primary drive cover, 1 nut, remove flywheel cover 3 spring clips, I changed the crank seals in less than an hour earlier today, what a simple bike it is to work on, anyway handover to Father tomorrow so he can continue to improve it, I guess the caveat is that you had to maintain these machines more often than modern bikes but wow it’s easy!.
Sir J.Stewart.
Offline masonmart
« Reply #36 on: March 30, 2019, 09:17:19 PM »
Nice bike Mark, I remember them well from the 60's. Other nice bikes to with 2T and 4T engines. They are real classics.
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Offline MarkCR750
« Reply #37 on: April 01, 2019, 04:26:14 PM »
Thanks Masonmart, yes it’s a nice thing considering it was made as a workman’s commuter back in the 50’s, well the handover to Father didn’t happen!, it ran beautifully on Saturday evening but on Sunday morning it resolutely refused to start, no idea why but the spark was weak, the night before it was very good, so I’m picking up an electrex electronic ignition kit for it on Friday, I had planned to fit one eventually but will do it straight away, also having it rebored, I’ve picked up a NOS oversize piston so I’ll get that done as well, I’ll be good for a few thousand miles then.
Sir J.Stewart.
« Reply #38 on: April 01, 2019, 04:32:34 PM »
Cor.those Villiers motors are tough.
Hope it finally gets sorted and the handover goes well
Offline masonmart
« Reply #39 on: April 01, 2019, 09:02:27 PM »
The problem I've had with classic 2T's of mine (super 6) is that eventually you can't get them to run well because the crankcase seals harden and fail through not being used. Small 2Ts were amazing then because there were so many different variations. They're difficult to use now because of the performance gap with modern traffic. Still fantastic bikes.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline MarkCR750
« Reply #40 on: April 01, 2019, 10:10:18 PM »
I had this T250 up until a couple of years ago, no problem keeping up with traffic on that as you know with your super six they go like stink!, no wonder so many 17 year olds came to grief on them back in the day, as you say the older 2 strokes are a different story, 60 mph flat out for the James and about a week to get there, worse than that though are the brakes, bloody terrifying by modern standards!
Sir J.Stewart.
« Reply #41 on: April 02, 2019, 08:45:48 AM »
I seem to remember that the condensers used to fail for a passtime and that could be your weak spark.
Offline Rozabikes Tim
« Reply #42 on: April 02, 2019, 02:56:31 PM »
Was that basically an off road Hustler?
Offline MarkCR750
« Reply #43 on: April 02, 2019, 04:32:29 PM »
Yes, in fact I think mine was a Hustler, I fitted the high pipes which I got for a bargain £70, it had chrome road pipes when I bought it, pretty much the only difference though.
Sir J.Stewart.
Offline MarkCR750
« Reply #44 on: April 05, 2019, 08:59:07 PM »
The condenser is being consigned to history tomorrow Bryan, and the points, and the brass flywheel, I went to Villiers spares in Brierley Hill today and bought an electrex electronic ignition kit, (had a “while you wait” rebore done as well), should achieve CB750 level reliability tomorrow, well almost 🙂
« Last Edit: April 05, 2019, 09:06:16 PM by MarkCR750 »
Sir J.Stewart.
