SOHC.co.uk Forums > CB500/550
CB500 K0 Carbs
Squiffy57:
Thanks for your inputs. I think that you are confirming that I've got the wrong carbs fitted!
Bryanj:
What size jets?
Squiffy57:
I've put in the standard 100 main jet plus all the other bits as per the kit from David Silver! Fine for a 627B but not for the 069A's that I've got.
However, I've just bought a set of 627B's from the US so I can pop them in the Ultrasonic cleaner, swap over all the jets, etc, that I've just fitted then hopefully Bob's your uncle!
Johnwebley:
Hopefully Robert is your mother's brother.
For future info.Cruzimage do carb rebuild kits.
Very good products and not expensive
Seabeowner:
Can someone identify what is different (apart from jets/needle position) between 627Bs and 069s. I thought they were pretty much the same. I've got 3 sets of 627s and one set of 069s. And have used a set of 627s in place of 069s on a 550 with no problems.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
