Author Topic: CB500 K0 Carbs  (Read 1023 times)
Offline Squiffy57
CB500 K0 Carbs
« on: March 21, 2019, 01:38:56 PM »
Hi Guys and Gals. I've just got my hands on a 1971 CB500 K0 fitted with 069A Carbs and am really struggling to get it to run rich enough despite having rebuild them and fitted all new jets, etc. I am beginning to wonder whether these are the correct carbs for the bike? Any ideas.....
Re: CB500 K0 Carbs
« Reply #1 on: March 21, 2019, 02:00:32 PM »
Have you got standard air filter and exhaust?
Re: CB500 K0 Carbs
« Reply #2 on: March 21, 2019, 02:04:26 PM »
Are 069A's fitted to CB550/4 F models? Not sure if they are fitted to CB500/4 but most probably.
« Last Edit: March 21, 2019, 02:08:36 PM by Nurse Julie »
Re: CB500 K0 Carbs
« Reply #3 on: March 21, 2019, 02:11:32 PM »
I thought the 500s all used 627B carbs?
2022 Tiger Sport 660
Re: CB500 K0 Carbs
« Reply #4 on: March 21, 2019, 02:39:22 PM »
I have just had a look at Trigs 500 and it has 627B's fitted.
Offline Squiffy57
Re: CB500 K0 Carbs
« Reply #5 on: March 21, 2019, 02:52:52 PM »
Thanks for your inputs. I think that you are confirming that I've got the wrong carbs fitted!
Re: CB500 K0 Carbs
« Reply #6 on: March 21, 2019, 02:53:57 PM »
What size jets?
Offline Squiffy57
Re: CB500 K0 Carbs
« Reply #7 on: March 21, 2019, 04:52:40 PM »
I've put in the standard 100 main jet plus all the other bits as per the kit from David Silver! Fine for a 627B but not for the 069A's that I've got.
However, I've just bought a set of 627B's from the US so I can pop them in the Ultrasonic cleaner, swap over all the jets, etc, that I've just fitted then hopefully Bob's your uncle!
Re: CB500 K0 Carbs
« Reply #8 on: March 21, 2019, 05:56:30 PM »
Hopefully Robert is your mother's brother.
For future info.Cruzimage do carb rebuild kits.
Very good products and not expensive
Offline Seabeowner
Re: CB500 K0 Carbs
« Reply #9 on: March 22, 2019, 01:07:47 PM »
Can someone identify what is different (apart from jets/needle position) between 627Bs and 069s. I thought they were pretty much the same. I've got 3 sets of 627s and one set of 069s. And have used a set of 627s in place of 069s on a 550 with no problems.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline Raymond_Y
Re: CB500 K0 Carbs
« Reply #10 on: March 22, 2019, 01:19:02 PM »
Having just refurbished a set of 627Bs and a set of 069As, the only difference I could see, was the main and slow jets.  (100 / 40 v 98 / 38)
Raymond
Raymond
1971 CB500K0 (being rebuilt)
1977 CB550K3 (bases for future 650 cafe racer)
Q plate CB550 in bits
Re: CB500 K0 Carbs
« Reply #11 on: March 22, 2019, 01:20:56 PM »
Graham said the same... he has never been able to find any difference between 627B's and 069's other than jets etc
Offline Squiffy57
Re: CB500 K0 Carbs
« Reply #12 on: May 21, 2019, 07:49:16 PM »
Well I'm still struggling to get the bike to run properly. Re-checked timing and valve clearances but she just feels starved of fuel. Float levels set at 22 mm and all new jets and even removed the fuel strainer and air filter to eliminate these as being a cause of the problem.
Was wondering whether it is possible to fit the emulsion tubes too high in the body of the carb so that the needle valve is closing down the fuel flow too much?
Any thoughts from anyone will be greatly appreciated.
