Author Topic: Camchain tensioner fitment 550  (Read 717 times)
Offline shifter
« on: April 25, 2019, 11:47:31 AM »
Been ask a thousand times I expect, am planning to replace the camchain tensioner on my 550, is it easy or possible to do this in situ in frame by removing cam cover and head etc .. would appreciate some tips etc if possible. Cheers ..
" RIDDEN NOT HIDDEN"
 Moto morini 250 2c
Cb200
S90
Re: Camchain tensioner fitment 550
« Reply #1 on: April 25, 2019, 02:52:46 PM »
Why are you replacing it?
Yes you can remove head in frame, you need a decent manal, 3/8 metric socket set with 6 sided sockets, gasket set time and patience. Read the manual about refiting the cam cover then read it again, then again so you really comprehend it or you WILL bend valves and maybe break valve guides!
As the head will be off new stem seals is a good idea
Offline shifter
« Reply #2 on: April 25, 2019, 03:35:56 PM »
Thankyou Bryan, one of the previous owners have knackered the slot on the adjuster which I recut with the dremmel also the thread is non serviceable , so I was looking for some tips I have previously taken the cam cover off etc (holding rockers up with elastic bands when refitting) it’s just about taken the head off in the frame also the removal of the tensioner, armed with (6 sided sockets etc ) Clymer/Haynes , As you say will replace seals while I’m there ,  so new guide and blade do you think .( my bride (70) says I have no patience ONLY  when messing with engines , must have been an Hgv syndrome 😜, thanks again ...
 Moto morini 250 2c
Cb200
S90
Offline mickwinf
« Reply #3 on: April 25, 2019, 05:37:25 PM »
another thing to watch when replacing the tensioner assembly is make sure the bottom part is correctly located, it can be a bit fiddly
« Reply #4 on: April 25, 2019, 05:44:09 PM »
All the parts you need are same as 500, Dave Silver does a complete tensioner but it is a bit pricey.
Honda genuine manual is in Ash's dropbox.
I have posted many times on both sites about not putting a screwdriver in that slot as it knackers the rack/pinion mechanism.
If you have had the cover off you know about the soft washers between the steel end bracket and cover.
Can't think of much else but if you need to chat PM me and i will send you a number and time when i am at work.
Offline shifter
« Reply #5 on: April 26, 2019, 06:55:05 AM »
Many Thanks Guys for the  advice ... much appreciated .....
 Moto morini 250 2c
Cb200
S90
Offline Seabeowner
« Reply #6 on: April 26, 2019, 09:04:09 AM »
I always remove the sump so that I can see the tensioner located correctly in its pocket.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline Genniker
  • 500/4
Re: Camchain tensioner fitment 550 - manuals
« Reply #7 on: April 27, 2019, 09:52:34 AM »
Hi new to the site so trawling for and picking up a lot of good information here. Very intrested in the reference to accessing Honda manual from 'Ash's dropbox' Where would I find that and can anyone access it?
« Reply #8 on: April 27, 2019, 10:05:02 AM »
Look in alladins cave in list at top, or if you want manuals and parts books on cd i can supply for a small cost as Ash got them from me in first place.
