Author Topic: Cylinder head  (Read 2088 times)
Offline heliwilly
Cylinder head
« on: September 05, 2019, 11:31:00 AM »
I have seen two methods of tightening the cylinder head.
1/ Tighten to 16ftlb, leave 24 hrs, retighten to 16ftlb leave 24hrs, lastly check and tighten to 16ftlb.
2/ Tighten to 14ftlb leave 24 hrs, tighten to 15ftlb leave 24 hrs, finally tighten to 16ftlb
Which, if either, is correct. TIA
Bill W.
« Last Edit: September 05, 2019, 03:57:30 PM by heliwilly »
Re: Cylinder head
« Reply #1 on: September 05, 2019, 11:54:35 AM »
Whatever is sez in the Honda manual mate, do you really believe dealers back then waited 24 hours before getting the bike out of the workshop?
I never had any problems with Hondas method
Offline deltarider
Re: Cylinder head
« Reply #2 on: September 05, 2019, 12:46:09 PM »
Interesting topic! In my archives I have several socalled Rider's Reports on the CB500/550 published back then in then a weekly (!) motormagazine. In these articles were the typical complaints listed that CB500/550 owners met during many years and kilometers. High on the list were the plugcaps. Also high was the almost inevitable sweating of oil at the head gasket. In one of these articles the chief mechanic of Honda Netherlands, the man at the importer that instructs the dealers, gave his advice. Before tightening the head nuts, he advised to oil the washers somewhat with Molykote and then torque down to the original torque values prescribed in the Shop Manual. Can anyone explain how this can be benificial? I always thought torquening bolts/nuts using grease is a no-no. Now here the advice concerns the washers, but still I would like to know.
Offline florence
Re: Cylinder head
« Reply #3 on: September 05, 2019, 01:37:39 PM »
When I put my engine together I followed what it said in the manual and never have I needed to touch it again.
Offline heliwilly
Re: Cylinder head
« Reply #4 on: September 05, 2019, 02:05:15 PM »
Contributors are talking about the figures in the "Manual". Which Manual are they referring to? All I have is the Haynes one which is limited.
This is the first CB550 that I have rebuilt and it was a non-runner that had been taken apart previously. I am coming across things that don't seem as they should be. The cylinder head nuts are a typical example. Are they supposed to have 2.25 mm washers under the head nuts? 7 of the nuts have 2.25 mm washers with the remainder having a selection of different thicknesses.
All help would be gratefully received.
Bill W.
Re: Cylinder head
« Reply #5 on: September 05, 2019, 02:37:04 PM »
Torque figures are usually given for dry threads UNLESS it's stated to use a specific lubricant.
Torque wrench effectively measures friction (rotary in this case) so placing a lubricant on the washer and using the same torque setting figure will then stretch the stud more than without lubrication.  A higher clamping pressure in applied,  as long as the tensile strength of the stud is not breached.
It's a more involved topic for such a simple action than is generally realised, we could do a thread on that if wanted.
Offline deltarider
Re: Cylinder head
« Reply #6 on: September 05, 2019, 02:48:32 PM »
Excellent idea! BTW, were CB550s any better in this than the CB500?
Offline Tomb
Re: Cylinder head
« Reply #7 on: September 05, 2019, 03:27:45 PM »
Strange, in my work as Mech Fitter we have to go on courses regarding use of our torques wrenches, we are told the opposite, there is little point torqueing dry threads as the torque figures are meaningless, moreover, we are given different torque settings depending on which lube we use. Copaslip or Copperslip
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Re: Cylinder head
« Reply #8 on: September 05, 2019, 03:49:46 PM »
Isn't that in agreement (both those two methods)? In that a lubricant is specified and torque match to those materials.
Possibly looking at it from the design point of view compared to practice in use will expose the process of arrival at final specification as directed to your interaction.
But to understand in this application,  do Honda specify any lubricant for those head studs on assembly?
Offline heliwilly
Re: Cylinder head
« Reply #9 on: September 05, 2019, 04:01:21 PM »
Does anyone have an answer to my original question?
Bill W.
Offline hairygit
Re: Cylinder head
« Reply #10 on: September 05, 2019, 04:05:28 PM »
The first answer was the correct one. Tighten once and ready to use. Honda in later revisions made head gaskets as a "sandwich" with sealant inside which squeezed out when tightened ensuring a leakproof joint. ALWAYS use a genuine head gasket if you can get one.
Offline jon stead
Re: Cylinder head
« Reply #11 on: September 05, 2019, 04:19:48 PM »
Re: Cylinder head
« Reply #12 on: September 05, 2019, 06:04:22 PM »
Thickness of washers probably dont matter but material type would so i would make sure all are Honda ones to make clamping same.
Personally never used any lube BUT before fitting head made sure that nuts "ran" up and down studs freely so that you are measuring the clamping torque not friction on the thread.
Any lube on the thread makes a vast difference to the torque required so you should stick to the genuine Honda manual, available in alladins cave as provided by Ashimoto who copied my manuals and parts books.
As an asside VOSA have for years been trying to find the reason for HGVs loosing wheels and no definitive answer has ever appeared, old style cone nuts were fitted dry whilst new style integral washer type are oiled, go figure.
Offline heliwilly
Re: Cylinder head
« Reply #13 on: September 05, 2019, 06:16:17 PM »
Thanks for that. I too have always torqued up dry, but wondered why the 3 stage suggested by some. to me it seems a better way of doing it given the time. Thanks Bill W.
Offline heliwilly
Re: Cylinder head
« Reply #14 on: September 06, 2019, 05:40:13 PM »
It would appear that the cylinder head flanged nuts do have 2.25mm washers underneath them, so that is the way I will go.
I found this out by taking the head off a 550 engine that had been left in the open with no plugs in.
Now the head is off the pistons in the barrels are soaking in paraffin. Hopefully it may eventually creep past the pistons and rings.
A 2ft breaker bar wouldn't move the crank.  Bill W.
