Author Topic: Sump plug sealing washer  (Read 2097 times)
« on: September 18, 2019, 08:25:33 PM »
  if your alloy washer is knackered,or just goes missing.
 try a Dowty Washer/seal.
  perfect
  just visit a local hydraulic hose dealer ,cheap as chips
https://en.wikipedia.org/wiki/Bonded_seal
Re: Sump plug sealing washer
« Reply #1 on: September 18, 2019, 08:51:26 PM »
Unless you go to my local hydraulic place that has a £10 + vat minimum order even for cash!
« Reply #2 on: September 18, 2019, 10:08:45 PM »
  I went to local place .
  £1  for 4
« Reply #3 on: September 19, 2019, 07:53:06 AM »
Nice one Ken ... We could do with a feature on here that lists all of this stuff, like electrical, seals  etc. I know we have recommended services but one post would be best (bit like the Dropbox literature links) . I don't mind doing it .
Edit: Started the ball rolling PM me with anything you would like adding  :)
http://www.sohc.co.uk/index.php/topic,20169.msg179113/topicseen.html#new
« Last Edit: September 19, 2019, 08:07:06 AM by AshimotoK0 »
Offline gtmdriver
« Reply #4 on: September 19, 2019, 10:18:49 AM »
You can get Dowty washers in small quantities and in a large variety of sizes on eBay.
« Reply #5 on: September 19, 2019, 05:01:58 PM »
I have used 6mm Dowty type instead of the expensive special fibre washers in the fuel tap
