Author Topic: running like a dog part III  (Read 2686 times)
Offline philward
Re: running like a dog part III
« Reply #15 on: October 03, 2019, 03:54:50 PM »
Great news Paul! Hope that's it sorted
PS - Ref my previous suggestion - misread your post prior to my suggestion as if misfire was on 1 - 4 (hence same ignition circuit) - yet another senior moment! (becoming ever more frequent!
« Reply #16 on: October 03, 2019, 11:59:50 PM »
Nothing wrong with senior moments-------what were we discussing?
Offline paulbaker1954
« Reply #17 on: October 04, 2019, 11:10:41 PM »
SUCCESS!!!!!!
New plugs fitted today, synced carbs, sorted malfitting plug caps
PURRING LIKE A KITTEN NOW
This has been a frustrating but valuable learning curve but with fully reconditioned head, new plugs, new inlet rubbers with decent clips and nicely balanced carbs this bike is running smoother than it ever has. Ticks over lovely at 1k
Yet to get out on the road but all now looking really good
Many thanks to all who have added advice and wisdom over the last few weeks, that’s why this forum is so great and the advice and ideas have been so much more useful than the so called pro mechanic I used. I am not dishing him just that intimate knowledge of these bikes is so valuable which he did not have.
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
« Reply #18 on: October 05, 2019, 08:31:46 AM »
Some times it is obvious that it is unbelievable  :o
Had a twin in last year for a new cam chain, easier to drop the engine to do this job. New chain fitted, engine back in but, no spark. Instead of the mind thinking, no electrics have been disconnected apart from the alternator, i started by changing the plugs, then the coils and caps, then the CDI unit, then the pick up. Lucky i had the same bike sitting in the workshop so just swapping parts and scratching my head. Right i thought, it must be the ignition switch and as i lowered the ramp, i noticed the kill switch was off  ::)
Offline philward
« Reply #19 on: October 05, 2019, 08:11:17 PM »
I think that most of us have been caught out by that kill switch Graham
Offline Erny
  • CB750K7 CB550K1
« Reply #20 on: October 05, 2019, 08:19:49 PM »
Kill switch! It happen to me too! I can imagine that... I never use it, so if by whatever chance it becomes off, I have problem ;)
CB750K7 US model (1977)
CB550K1 US model (1975)
« Reply #21 on: October 05, 2019, 11:02:44 PM »
Pleased to hear it’s just not me that misses the obvious sometimes. Spent 5 minutes in Ireland this summer pressing the starter on my Yam Tracer and engine not turning over, eventually realising it was in gear and there is an inhibitor switch that stops you starting it in gear!!!
« Reply #22 on: October 12, 2019, 11:34:31 PM »
Well finally got out on the road today and pleased to report that after all the work my bike is running better than it ever has👍👍👍👍 just a small panic caused by a kinked fuel feed hose after 2 miles (easy fix!!)
The new rubbers and decent clips have resulted in a smoother tick over than it has ever had and the head skim has finally resolved the oil leak where this tale began ( oil was seeping out around the timing chain area of the head)
Many thanks to all who have helped with advice and put up with my frustration over the last weeks, this forum is just a great resource
« Last Edit: October 12, 2019, 11:36:12 PM by paulbaker1954 »
Offline Erny
  • CB750K7 CB550K1
« Reply #23 on: October 15, 2019, 06:54:13 AM »
Great news Paul! Keep riding and enjoy your bike
« Reply #24 on: October 15, 2019, 06:16:20 PM »
Well done Paul that’s a great result.
