Author Topic: CB550F Main Jets  (Read 3465 times)
Offline cooleronthecoast
Re: CB550F Main Jets
« Reply #15 on: November 14, 2019, 05:55:53 PM »
Its all interesting stuff guys and gals, but does anyone have a single 100 main jet sitting on a shelf they can sell me so I can have 4 that match?
Now where did I put that 10mm socket?
« Reply #16 on: November 15, 2019, 09:47:04 AM »
Thats great mate.  I'll have those please.  I'll pm you with my address details later today and if you have Paypal let me know your addy and I'll sort out the money too. If not just let me know how you want me to pay.
Offline oldboy
« Reply #17 on: November 19, 2019, 08:41:10 PM »
I've just removed 98's from my 500 carbs to fit 105's. If you drop me your address you can have them.
« Reply #18 on: November 20, 2019, 03:32:00 PM »
Thanks mate, I've asked Oddjob for the ones he offered so I should be fixed up shortly.
Offline oldboy
« Reply #19 on: November 20, 2019, 03:59:29 PM »
Sorry they were 100's. Would not surprise me if these are 550 carbs, the more I do on this "500" the more I find wrong!!
« Reply #20 on: November 20, 2019, 04:14:21 PM »
Did we not ascertain a while back that the CB500/4 and the CB550/4 F model (non PD's which are on the 550/4 K's) are exactly the same carbs, just with different jets fitted. I know both myself and Trig have had plenty of both through our hands and have never, ever found a difference.... other than the jet sizes that were fitted by Keihin at manufacture. So, a 1971 500/4 has 627A, a 1972 CB500/4 has 627B's and a CB550/4 has 069A's fitted, which are identical carbs, all but for jetting.
« Last Edit: November 20, 2019, 04:24:21 PM by Nurse Julie »
« Reply #21 on: November 20, 2019, 04:31:26 PM »
Julie, do you know why the 550F has 98 size main jets whilst the 550K has 100's?   At least thats what my Haynes manual tells me.  I was thinking because of the different exhausts but I haven't got a clue really.
« Reply #22 on: November 20, 2019, 04:35:32 PM »
I know diddly squat about jetting really and can only assume it has to do with the CB550/4 K having Keihin PD carbs fitted which run very, very lean. The K3 was built primarily for the USA market and the bikes had to fit in with their strict emission regulations.
« Last Edit: November 20, 2019, 04:40:08 PM by Nurse Julie »
Offline deltarider
« Reply #23 on: November 20, 2019, 06:24:32 PM »
Maybe you like to consult this.
« Reply #24 on: November 20, 2019, 06:47:28 PM »
I don't think that's correct, never seen or heard of a #78 main jet on any Honda, let alone a CB500/4 🤔🤔🤔🤔
Offline deltarider
« Reply #25 on: November 20, 2019, 07:29:32 PM »
Except for France, all CB500s on continental Europe had the #78 main jets. Again, see the parts lists. Also Honda listed the #78 main jets as a possible alternative for the standard #75 on the CB400F. See the CB400F parts list, p.17 http://www.honda4fun.com/pdf_parts_list/pdf_spac400/CB400F-F1-F2/CB400F-F1-F2.pdf
« Last Edit: November 20, 2019, 07:34:48 PM by deltarider »
« Reply #26 on: November 20, 2019, 07:34:46 PM »
That doc,  linked above,  shows different id for needle set,  idle screw and filter to be paired with the #98 main jets.
Whether the carb set designated number changes for the whole bank setup,  and without body casting changes, is not apparent.  But I suppose it would be logical on production line and feed stock to identify the different spec externally if they where in production at the same time but destined for different markets.
« Reply #27 on: November 20, 2019, 07:49:23 PM »
You're just confusing the issue Delta. It was a simple thread that has got stupidly complicated for no reason.
Offline deltarider
« Reply #28 on: November 21, 2019, 10:03:39 AM »
That's not fair, Julie. I did not start about the #78 jets that just happen to be in my overview  that was modestly attached as a PDF in reply #26. It was you yourself that opened it and then commented:
I don't think that's correct, never seen or heard of a #78 main jet on any Honda, let alone a CB500/4 🤔🤔🤔🤔.
That compelled me ofcourse to correct that again because, what is not corrected, lives on as truth eternally on the internet. Except for France, all CB500s*, no matter what year, on continental Europe had the #78 main jets and we're talking tens of thousands of bikes here, some of which may even have surfaced in the UK nowadays.
* The CB500K3 model being an exception ofcourse. That model had the PD carbs.
Offline deltarider
« Reply #29 on: November 21, 2019, 10:32:35 AM »
...So, a 1971 500/4 has 627A, a 1972 CB500/4 has 627B's...
Does anybody know what may have been the difference between the 627A and the 627B carbs? Has anyone actually seen 627A carbs in real life?
