Author Topic: 400/4 Battery not charging  (Read 3904 times)
Offline THUNDERDOWNUNDER
« on: November 24, 2019, 05:01:12 AM »
Ideas needed for fix . At the moment I have to charge my battery off the bike . Fully Charged it lasts about Half an hour . Starts on the button then looses power fast no starter and indicators stop . If I fully charge and leave it over night it drains . So what’s wrong Guys ?
Re: 400/4 Battery not charging
« Reply #1 on: November 24, 2019, 08:22:31 AM »
Most likely is corroded connectors then regulator then rectifier.
You need a decent multimeter and a methodical approch to sort out electrical problems
« Reply #2 on: November 24, 2019, 08:50:33 AM »
Good place to start:
Place voltmeter on battery terminals and start engine. Run up to 4000 revs.
What voltage do you see?
2022 Tiger Sport 660
« Reply #3 on: November 24, 2019, 09:36:37 AM »
At 4000 rpm it’s readin 12.41.  At tic over it’s 12.34  .
« Reply #4 on: November 24, 2019, 10:25:03 AM »
How old is the battery?
Get it load tested
« Reply #5 on: November 24, 2019, 10:31:52 AM »
That’s nowhere near enough.
When you charge it off the bike, is it the same?
« Reply #6 on: November 24, 2019, 11:17:22 AM »
The battery is only a few months old . So don’t think it’s that . When I bought the bike a few years ago the owner said there was a short somewhere . I have put a new wiring loom on . So it’s down to the generator or regulator/ rectifier
Offline cooleronthecoast
« Reply #7 on: November 24, 2019, 11:30:31 AM »
It does sound like the charging system is at fault, as Steve says you should be seeing a much higher voltage than you are at 4000 rpm
Now where did I put that 10mm socket?
« Reply #8 on: November 24, 2019, 11:53:29 AM »
With the battery loosing power over night where is the short ?
« Reply #9 on: November 24, 2019, 01:15:23 PM »
Disconnect the 3 wires from the regulator, with ignition on check voltage at black reg wire with ignition on it should be same as battery voltage.
No more instructions till that andwer posted
Offline Moorey
« Reply #10 on: November 24, 2019, 01:58:09 PM »
What kind of battery is it. If your battery has been deeply discharged several times it could well be knackered now. Remove it from the bike and fully charge it. Remove charger and leave it to stand for a couple of hours to settle out.  Then check voltage. Leave it to stand for at least a further 24hrs and check again the battery voltage. It should be between 12.7 to 12.5 this is for lead acid and gel type. Batteries can collapse inside and take on any charge given but not store it and at the same time will cause low voltage readings at the posts when checking with the engine running. Also decent voltage readings alone do not always mean a healthy charging circuit as you can have good volts but may only be getting milliamps to the battery.
« Reply #11 on: November 26, 2019, 12:13:48 AM »
Thanks BryanJ  I will give it a go latter today if I can get a chance . I will be away for the next week so will get back to you as soon as . Rob .
« Reply #12 on: November 26, 2019, 02:13:11 AM »
No problem, i work nights so you get answers at odd times! Easier to give you 1 test at a time even though it will take longer
« Reply #13 on: November 26, 2019, 03:18:58 AM »
Great stuff thanks for the help !
« Reply #14 on: December 09, 2019, 10:28:58 AM »
Back now . Tested as recommended . Wires off regulator . ignition on .  test came out at 0.07 volts Battery was 13.10 volts . That was testing black wire only Black wire from multimeter to black wire from regulator and red wire from multimeter .
to positive on battery .
