Author Topic: Refitting carbs But airbox bits missing  (Read 1876 times)
Re: Refitting carbs But airbox bits missing
« Reply #15 on: March 09, 2020, 08:03:21 AM »
I have this part for sale on ebay. Part number 17319-323-000
Sent from my I3312 using Tapatalk
BZP looks a bit dodgy on that Julie (perfectly good to use of course and a rare item) .. did our friends in E/Yorks plate it? Dropped a batch off there last month ..... lead times 6 weeks+ which is a lot longer than they normally take. Took a 400/4 rear sprocket guard plate in there for dark olive drab plating, with a pile of other parts ... interesting to see how it comes out.
« Reply #16 on: March 09, 2020, 08:52:44 AM »
Yes Ash, this parts was as pitted as pitted could be so it's come out quite well considering. The BZP itself is fine, (yes, done by our usual boys) but it will not show when fitted and seemed a shame to just throw it in the skip.
Offline bobv7
« Reply #17 on: March 09, 2020, 03:54:07 PM »
Sorry, it's me again! :-[
I don't mean to be a pain but I really don't want to have to do this again! Which side do you set the slides from, front or back? :o
« Reply #18 on: March 09, 2020, 04:03:23 PM »
Not the side in your photo.... So the front side of the carbs.
« Reply #19 on: March 09, 2020, 04:07:32 PM »
This side
« Reply #20 on: March 09, 2020, 04:14:56 PM »
How big is the gap at the bottom of the slides with the idle screw backed off fully Bob, just out of interest and do the gaps look equal?
Offline bobv7
« Reply #21 on: March 09, 2020, 04:29:40 PM »
Ok, I just checked with a drill bit and it's 3.2mm which is about one eigth of an inch in old money. Too big? This is the engine side.
« Reply #22 on: March 09, 2020, 04:38:53 PM »
(Attachment Link)
Yes, you are on the correct side of the carbs and 3.2 mm sounds far too big. More importantly, do the slides close fully when you back off the big idle adjuster?. This is what my red squirt tube measures
« Reply #23 on: March 09, 2020, 04:41:07 PM »
Way too big i use 1/16 or smaller.
Looking at picture 2nd from right looks more open than 2nd from left
Offline bobv7
« Reply #24 on: March 09, 2020, 04:50:20 PM »
Thanks all, measure from the engine side not the intake. But tomorrow is another day and my knees have given up! :-\
« Reply #25 on: March 09, 2020, 04:52:28 PM »
Well done Bob, I know you will get it sorted soon.
« Reply #26 on: March 09, 2020, 04:54:17 PM »
Yes, I  noticed there was no parity there Bryan.
Offline bobv7
« Reply #27 on: March 10, 2020, 11:01:18 AM »
Morning all
Well I went out armed with the regulation bit of red tube (off a WD40 Can) and it don't fit under the sides! :o What am I doing wrong! :-\
« Reply #28 on: March 10, 2020, 11:09:33 AM »
You need to be going through the procedure on each carb slide as described in the link to Bryan's post. You need to unlock to lock nuts on the top of each slide, where my finger is pointing to, and screw the adjuster up and down to get the correct height of each slide and lock it off again. You need to do this with all 4 slides. It also looks like the red tube isn't in the centre of the gap, which it needs to be.
« Last Edit: March 10, 2020, 11:14:25 AM by Nurse Julie »
« Reply #29 on: March 10, 2020, 11:30:27 AM »
What you are aiming for after adjusting Bob is parity of gap on all 4 slides and all 4 slides to be closed fully when the idle adjuster is backed off totally. So, when you twist the big idle adjuster, the slides lift up and the gap is exactly the same under each slide which adjusts the idle tick over on all 4 carbs equally.
