Author Topic: UK Plate Bracket?  (Read 1491 times)
Re: UK Plate Bracket?
« Reply #15 on: May 04, 2020, 08:16:18 AM »
Here is Oval lamp ..95 mm between mounting bolt centres.
« Reply #16 on: May 04, 2020, 08:38:37 AM »
Thanks Trigger.  My bracket has the same measurements as the bracket in Trigger's post.  It looks the same with the square plate mount and the rib.  Is this a CB750 bracket?  I ordered a repro oval taillight but it won't be here for a few weeks.
Scott
I answered your question in a previous post  :o The bracket you have is  P/N 84701 323 600B and is for the UK CB750 K2 from 1972 to 1975 and was from the UK CB500 Four 1971 to 1974 . Yes, a oval light should fit  ;)
Offline Rookster
« Reply #17 on: May 16, 2020, 10:31:35 PM »
I just wanted to update this thread.  I'm in the US and converting a Dunstall Honda back to stock configuration.  I have some choices to make about fenders and tail light.  I always liked the look of the UK tail light and black bracket.  I happened to come across one cheaply.  I took a chance that the US K2-K6 rear fender would have the same bolt spacing as the UK bracket.  It does.  This is an original K2 fender with the UK bracket bolted on.
I'm still waiting for the oval tail light to get here but it should bolt up no problem.
Scott
« Last Edit: June 02, 2020, 06:00:52 AM by Rookster »
