Author Topic: Cb550k3 Rectifier  (Read 2242 times)
Cb550k3 Rectifier
« on: June 28, 2020, 05:57:45 PM »
Hi everybody, anybody cruising today? Went for a run just about 18miles switched to reserve fuel on my return to town so filled up, pushed starter button wouldn’t even turn over, thank god there’s a kick start lever. I came home checked voltage on battery 11.3 volts! Not good. No power whatsoever getting from alternator to battery. I have a suspect rectifier with a slightly fried red/white wire. Question is replace with just rectifier or replace with regulator rectifier. About the same cost wise from what I’ve seen so far.
1978 Honda CB550K3.
Re: Cb550k3 Rectifier
« Reply #1 on: June 28, 2020, 06:48:40 PM »
Im old school and prefer original to this new fangled electonickery.
Rectifiers rately go a used one will 80% be OK.
Offline nairb
« Reply #2 on: June 28, 2020, 07:11:30 PM »
On my 3 phase Suzuki gt550 I use a rectifier from fleabay  for less than 3 quid.  My 550K3 still has the original rectifier so I have not had to change it but it has the same wiring as the suzuki.  3 yellow 1 green and the Red/white?.  Well the suzuki is just red.  I have these fitted to all of the suzuki bikes and in 10 or so years not one has failed.
Its been a very cheap option.  Fleabay item search Sql35a
« Last Edit: June 28, 2020, 08:11:39 PM by nairb »
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2,  gt380 Kz750 twin cb360K0
« Reply #3 on: June 28, 2020, 07:33:08 PM »
Thanks very much guys, that rectifier looks very interesting, anybody else tried one? I think at that sort of money you can’t go wrong. Seen a couple on dk spares but everything advertised 39.99 postage and they don’t use Royal Mail which is cheapest for sending to Orkney, especially something that can be slipped into a small Jiffy bag.
1978 Honda CB550K3.
Offline cliff7
« Reply #4 on: June 28, 2020, 08:32:05 PM »
I fitted a similar one only a 50A one as it had built in heat sink fins (about a fiver) to a CB400F and it seems fine so far.
« Reply #5 on: July 04, 2020, 04:09:37 PM »
Fitted today, all seems fine, too wet for road test but passed garage run testing.
1978 Honda CB550K3.
« Reply #6 on: July 04, 2020, 05:49:10 PM »
Also to add to the discussion pot  http://forums.sohc4.net/index.php/topic,183347.0.html interesting related thread over on the USA sohc site that could be of interest.
Cb550k3 Rectifier
« Reply #7 on: July 04, 2020, 07:19:52 PM »
That tie-wrap needs to be black Jonny
2022 Tiger Sport 660
« Reply #8 on: July 04, 2020, 07:30:38 PM »
Your absolutely right just doesn’t look right! Quick get the side cover on before anybody else notices.😂😂
1978 Honda CB550K3.
« Reply #9 on: July 04, 2020, 08:41:21 PM »
Them there’s the white heat shrink…
« Reply #10 on: July 04, 2020, 09:21:35 PM »
Thought I did well finding bits and pieces of correct colour wire, unfortunately no green heat shrink. Added to shopping list  along with black cable ties!!
1978 Honda CB550K3.
Offline mike the bike
« Reply #11 on: July 04, 2020, 09:44:56 PM »
My 400 ground to a halt on the M4 due to a lack of volts.  One of the terminals had broken off the rectitifer  flush with the epoxy potting.  I  sharpened up a screwdriver and chiselled some of the epoxy away from the broken terminal so I was able to solder a new spade onto it.  That was about 7000 miles ago.
« Reply #12 on: July 05, 2020, 07:47:55 AM »
Good fix Mike! Was that a similar type rectifier? Wasn’t sure of the durability of these cheapo components. The temptation to spend £4 compared to £60 was overwhelming.😂
1978 Honda CB550K3.
« Reply #13 on: July 05, 2020, 08:57:23 AM »
Mine was the standard Honda item.  The difference between the OEM one and what you've got is, maybe,  the heatsink.   Yours might run a bit too hot and break down.  You can always add a heatsink to it if you think it's inadequate.  With a smidge of heatsink paste.
« Reply #14 on: July 05, 2020, 11:42:44 AM »
Thanks for that I did wonder about the heat side of it. I will keep an eye on it after a couple of longer runs, I will probably replace at some point with the correct item in keeping with the bike spec. (he says with his electronic ignition)🤫
1978 Honda CB550K3.
