Author Topic: Oil leak oil plug left side engine  (Read 4171 times)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Oil leak oil plug left side engine
« Reply #15 on: October 04, 2020, 11:53:01 AM »
Erwin if it’s definitely that leaking I was thinking of suggesting looking at the CMSNL site as sometimes they state the dimensions of the O rings, but it is not shown for this one. If you measure the thickness and inside diameter with a digital caliper micrometer it could be worth trying a fractionally fatter one. eg if the thickness is say an odd 2.8mm get the common size of 3mm with the same inside diameter (cheap on eBay)
It might just provide a tighter seal? Subject to views of those better qualified than me!
« Last Edit: October 04, 2020, 11:56:07 AM by jeremypeachey »
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #16 on: October 04, 2020, 12:16:40 PM »
If your sure you have the correct seal and that's undamaged the only other cause is damage in the bore or to the plug. Get a strong light and magnifying glass and check for scores or even a small crack in the bore. On the plug, remove the seal and make sure nothing is underneath it causing a pressure point against the back of the seal. With hot oil at pressure it really doesn't need much damage to cause a leak.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #17 on: October 04, 2020, 12:41:27 PM »
I have a parts list that describes it as O ring-9131930000-13x2.5mm
nice bike,nothing in the bank
Offline JezzaPeach
« Reply #18 on: October 04, 2020, 01:36:04 PM »
Ditto. I thought my brake caliper was fine but the groove the seal went in was minutely corroded or discoloured and leaked.
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #19 on: October 06, 2020, 10:25:28 PM »
Always used paper and a pencil down the plug hole for Triumphs with a mag. Im 68 and still learning
 ;D ;D
That’s how I got started in motorcycle mechanics. I tried to find TDC on a CB125S – my first bike – using a pencil with the inevitable result.
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
Offline Erwin83
« Reply #20 on: October 17, 2020, 03:55:05 PM »
Nope, if you run the engine with the alternator cover off that plug will disapear to the darkest, dingiest corner of your garage never to be seen again and a large puddle of oil appear under the engine
So I made a little plate to keep the plug in.
Uuuuunfortunately...
CB466f - KTM 1190 advR
Offline Erwin83
« Reply #21 on: October 17, 2020, 03:57:15 PM »
Not so much a puddle.. just a good 5 yards of spray, oil on the ceiling, bike's left side covered...
At least no questions about the performance of the oil pump...
Offline Erwin83
« Reply #22 on: October 17, 2020, 04:13:54 PM »
With regards to the solution of the actual leak.. I found that the plug was snug in the bore when the outside of the plug is around 1 mm deeper than the surface of the cover. That would mean that the oil pressure always pushes the plug out that 1mm, creating a gap between the bore and the aluminium of the plug. As such completely relying on the O-ring for sealing.
I have now placed a small bit of gasket material between the plug and the actual gasket, therefore keeping the oil plug in a bit deeper mechanically.
I also did some better cleaning of the bore and plug.
Let’s see if that does the trick.
« Reply #23 on: October 18, 2020, 12:33:06 PM »
;D ;D
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
« Reply #24 on: October 18, 2020, 12:41:12 PM »
This suggests to me that the "pip" on the plug has been shortened somehow
Offline Erwin83
« Reply #25 on: October 18, 2020, 01:22:01 PM »
Should it indeed be flush?
« Reply #26 on: October 18, 2020, 01:48:28 PM »
The "pip" should be flush with the gasket surface, if you look inside the generator cover there is a part of the casting that holds it in, if this pip has been damaged or shortened for some reason the plug will not be far enough in.
I have never seen this happen in 40 yrs but offer it as a possible explanation
« Reply #27 on: October 18, 2020, 02:04:21 PM »
Are you sure that you have a 333 bung as, the 323 bung is shorter  ;) The 323 bung has a depth of 16.50 mm but the 333 is longer .
Also if the bung has been pulled out with pliers, this damages the pip.
« Reply #28 on: October 18, 2020, 06:09:12 PM »
Never looked closely at the 400 one only the 500/550 so Trigger is probably correct
Offline Erwin83
« Reply #29 on: October 19, 2020, 09:14:35 PM »
I don’t really know. The pip doesn’t look damaged at all. Could I have a 350cc and 400cc bung mixed up? Is that the difference between the 323 and 333?
