Author Topic: Any GS500 experts here  (Read 981 times)
Offline JonnyB
  • Repeat: It's only a Hobby, It's only a Hobby....
    • BatchScan
« on: October 09, 2020, 07:48:40 PM »
So I have a gs500e K3 2003. that won't start.
I've done the usual checks and I'm at the point where I've done a compression test and the right hand cylinder was down to below 60PSI. did the add a squirt of oil thing and it did not change so valves, yes?
Stripped the head . new valve stem oil seals, a de-coke and relapped the valves.
Reassembled recheck the compression and it's the same, no improvement.
Here's the question. one of the shim buckets was very, very stiff to get out and back in. Is it possible that the bucket is not returninh completly back and holding a valve open?
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
Basket Case -  K100/1200 hybrid
John
https://batchscan.co.uk/
Offline Lynx
Re: Any GS500 experts here
« Reply #1 on: October 09, 2020, 07:51:41 PM »
Could be a bent valve.
Sent from my HTC Desire 530 using Tapatalk
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #2 on: October 09, 2020, 07:57:51 PM »
Yes thats possible and i have also seen broken guides but you should have seen that when you fitted seals. Non start can be a down or old battery as a lot of the electronic units need more than 10v when cranking to start.
Offline JonnyB
    • BatchScan
« Reply #3 on: October 09, 2020, 08:44:31 PM »
Thanks, I have already changed the battery. Bent valve... I guess it's another strip tease is in order.
It will have to wait I have. superdream I need to scrap for parts.
John
Offline Greg65
« Reply #4 on: October 10, 2020, 07:24:10 AM »
Hi Jonny,
No instant answer for you but here is a link to a dedicated GS web site in the States. Some very knowledgeable and helpful people, hope it helps.
https://www.thegsresources.com
Greg
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
Offline JonnyB
    • BatchScan
« Reply #5 on: November 07, 2020, 08:12:30 PM »
Got the GS sorted, turns out that one of the exhaust valves was slightly open, it's bucket and shim and I don't have the tools for it.  My mech mate, at Wrightway, Lincoln thinks that a PO dismantled the top end and put it back together wrong,
Just going over it now and reversing PO "customisations", like removing the black paint over the tail light cos it looked cool and putting full sized indicators back on it.
John
