Author Topic: On going electrical issue.  (Read 2858 times)
Re: On going electrical issue.
« Reply #30 on: October 27, 2020, 07:50:00 PM »
Again possibly a bullet connector, is there power on black wire to bulb? If so try grounding the wire at the neutral switch, if light works its switch if not break in wire from bulb to switch
Online Johnny4428
« Reply #31 on: October 28, 2020, 07:43:04 AM »
Thanks Bryan, yes grounding out from switch activated light, so I will check wire from switch to light panel if it’s ok I guess it will be switch.
1978 Honda CB550K3.
Online Johnny4428
« Reply #32 on: October 28, 2020, 08:44:23 AM »
Good continuity between switch wire and headlight connection, think must be the switch.
1978 Honda CB550K3.
« Reply #33 on: October 28, 2020, 08:45:02 AM »
If grounding it at switch put light on the switch is duff
Online Johnny4428
« Reply #34 on: October 28, 2020, 11:10:36 AM »
Yes Bryan, I will take it out and see if it can be revived until I replace.
1978 Honda CB550K3.
Online Johnny4428
« Reply #35 on: November 08, 2020, 07:11:52 PM »
Hi guys just studying some of the pics I took last week and noticed this, possible short and definitely can’t be correct position of this retainer.
1978 Honda CB550K3.
