Author Topic: Front brake  (Read 1974 times)
Re: Front brake
« Reply #15 on: November 10, 2020, 03:38:24 PM »
As long as it is capped its fine
Offline bobv7
Re: Front brake
« Reply #16 on: November 10, 2020, 05:21:31 PM »
Makes a change to have some good news. Thanks for that and the cap is well screwed on. :D
Offline Seabeowner
Re: Front brake
« Reply #17 on: November 10, 2020, 06:57:30 PM »
As part of servicing lots of car manufacturers specify changing the fluid every two, three or four years. A real money spinner for garages.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Re: Front brake
« Reply #18 on: November 10, 2020, 11:20:25 PM »
It is a good idea to change every few years as in a car with vent holes in the master ot does absorb water then if you need to brake a lot the fluid gets hot enough for the water to boil off causing vapour lock and lost brakes
Re: Front brake
« Reply #19 on: November 14, 2020, 10:53:32 AM »
Unless you can guarantee to get every last tiny bit of old fluid out dont use dot5.
That's why I am a big fan of dot 5.1 it's not overly expensive with lower hygroscopic spec plus it mixes with everything except dot 5.0.
