Author Topic: Been waiting since 1977!  (Read 3232 times)
Offline Andrew-S
Re: Been waiting since 1977!
« Reply #15 on: December 23, 2020, 09:17:44 PM »
Ok, got to ask, what is the 59 club?
Welcome from me too 'Vic', as said by SumpMagnet the 59 Club was formed by the Father/Rev Bill Shergold, see: https://www.the59club.co.uk/history-c1d3n
We used to all ride over to an old Church Hall in a side road in Hackney and then onto the burger van on the Battersea Bridge on Thursday nights back in the mid-70s and then race home to Brentford, happy days!
Incidentally, my first bike in 1974 was a SL125, a great little thing is was too.
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Offline mike the bike
« Reply #16 on: December 23, 2020, 10:29:09 PM »
Welcome to the brotherhood of bikers, for that is what we are.  As I discovered on my first holiday away from my parents, on my C90.  It broke down on my way to Cornwall and before very long, a chap on a Z650 stopped and gave me much needed assistance and I have since repaid that favour ten fold.
Tell us how you get on with your test and everything.
Offline philward
« Reply #17 on: December 24, 2020, 03:39:28 PM »
Funny thing about Vicars and bikes, we had a Father Tony Lloyd in Manchester who founded the 171 club in an old church hall, he bought one of the very first Z1s in the UK. He was a really nice bloke and helped me out on more than a few occasions. In the cellar was a workshop where you could work on your bike and he had special tools you could rent like a set of vacuum gauges for the Honda fours.
Sadly Tony has long gone but there was talk of Granada making a documentary about him which I think would be well warranted.
If your up there Tony and reading this can I say thanks for everything.
I used to ride up to the 171 club from Wigan once a week Ken - He was a great guy it was a great club - he had a GT750 Kettle when I first went to the club (late 71, early 72?). Always remember when he used to relay a tale of someone else who was swearing - he used to substitute the word 'Kinelle' for the swear word of a similar sound! Another character was a guy we used to call 'Heir Doctor' (he was an ex doctor) a huge man in his 70's who rode a Read Titan 750 Honda (cr750 Honda type cafe racer) - he rode like he was 20 I was told!
Offline The Vicar
  • Been waiting so long for this to happen.
« Reply #18 on: December 29, 2020, 10:48:43 PM »
As the bike has a KMH speedo, how easy is it to find & to fit a MPH speedo?
1973 Suzuki TS125
1982 Honda XL250R
« Reply #19 on: December 29, 2020, 10:57:27 PM »
Fitting very easy, finding maybe not. You need to find out if it was sold in any market where mph was used instead of kph
Offline haynes66
« Reply #20 on: January 02, 2021, 07:13:21 PM »
once you pass your test, "the last shall be first"!
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline Moorey
« Reply #21 on: January 02, 2021, 08:21:51 PM »
 Or use one of these, I take it it's a cable drive.
  https://www.mandp.co.uk/products/kph-mph-top-cable-mount-converter-501839
Offline adespin
« Reply #22 on: January 02, 2021, 11:31:15 PM »
Yes, for my sins I am a Vicar!
Welcome Vic,  "for my sins" surely your slate should be clean in your trade  ;D
1971 cb750 K1
Offline The Vicar
« Reply #23 on: January 04, 2021, 08:23:15 PM »
Yes it is cable drive, & as its a Honda it looks like it fits on the rear of the speedo.
Thanks for the info!
1973 Suzuki TS125
1982 Honda XL250R
Offline The Vicar
« Reply #24 on: January 18, 2021, 08:04:47 PM »
I started it up yesterday & gave it a run [about 400 yards in a circle a couple of times, living next to a Church can be useful] I noticed a slight petrol leak from the fuel cock [this is what I would call it] when moving it from off to on, but then the leak stopped once in the on position [it seems to occur when moving the tap]. Anything to be concerned about, do I need to get a new fuel cock?  Looks like £7 to £30 for a new one on internet.
Upon further investigation I could still smell fuel in that area, & found that there is a very slight leak from the bottom of the carb [I say slight, it doesn't drip, but if you touch it you can see the wetness on your finger & it smells strongly].  Once again is this something to be concerned about?  It only occurred after running it for 10 minutes or so.
From what I can see there is what looks to me like a drain tube coming from the bottom of the carb [float chamber??], & directly above it a screw.  Is the screw the open/shut device for draining the carb?
Many thanks
1973 Suzuki TS125
1982 Honda XL250R
« Reply #25 on: January 18, 2021, 08:19:48 PM »
The brass screws are for draining the float bowls.  The tubes are overflows in the event of a float valve sticking and over filling.  You may benefit from replacing the O rings behind the brass screws.  Use a large flat blade screwdriver with a good fit in the slot to avoid damaging the slot.  Brass is soft and easily damaged. I find that tightening them slightly before loosening will overcome any tendency to stick.
I would strip and clean the petrol tap.  It's best done with the tank off and with the tank mostly drained.  Remove the two screws on the front plate of the tap,  remove all the bits and give them a good clean and polish.  Reassemble and test.
Hope this helps.
Offline The Vicar
« Reply #26 on: January 19, 2021, 10:12:33 PM »
Where would I get new O rings from?
How do I get the tank off, its not obvious how the seat is removed, which I presume has to come off first?
1973 Suzuki TS125
1982 Honda XL250R
« Reply #27 on: January 19, 2021, 10:19:17 PM »
Open the seat with the key, it doesn't have to be removed,  you'll see a rubber tank mount with a sticking out tongue.   Pull the tongue towards the rear to release the tank.  You'll have to take the tube off the tap first.  Once the rear mount is released, lift the tank a few inches and pull it rearwards.
Ask Julie the Seal for O rings, she's the go to gal for stuff like that.
Offline The Vicar
« Reply #28 on: January 20, 2021, 11:06:18 AM »
How do i contact this Julie?
1973 Suzuki TS125
1982 Honda XL250R
Offline robvangulik
  • Honda Fourever
« Reply #29 on: January 20, 2021, 11:19:02 AM »
She was the fourth to welcome you in this same topic, send her a PersonalMessage....
