Author Topic: 500 Engine Installation - with or without head on?  (Read 659 times)
Offline philward
« on: February 19, 2021, 09:00:36 PM »
I will have barrels fitted to the 500 by next weekend (awaiting piston clamps) and know from reading previous posts over the years that engine can go in without head, then fit head whilst engine in the frame. I'm not too bothered about the weight issue so what the pro's and cons of fitting head when engine in frame? - i.e. frame in the way making certain bolts, etc awkwards to fit.
Took the engine out complete and only used to fitting 750 engine - were you can only fit complete
Online Johnwebley
Re: 500 Engine Installation - with or without head on?
« Reply #1 on: February 19, 2021, 09:08:56 PM »
I believe you can fit the head.
But it  may help to leave the breather cover off.
Others with more experience will comment.
Offline Charlie J
« Reply #2 on: February 19, 2021, 09:24:48 PM »
I fitted my 500 engine last week. I did it with the head on by lowering the bare frame onto engine which was resting on its right hand side. I left the breather cover off and found the whole operation to be quite straightforward. I don't think it would have been too much of a problem lifting the engine into the frame in an upright position. The engine should go in from the left hand side.
Offline Charlie J
« Reply #3 on: February 19, 2021, 09:32:50 PM »
PS
I also left the oil filter cover off
Offline philward
« Reply #4 on: February 21, 2021, 11:19:39 AM »
I'll go with your advice Ken but put the barrels on on the bench for ease of installing the rings - thanks everyone!
