Author Topic: CB350 1971 Restoration Project  (Read 16343 times)
Re: CB350 1971 Restoration Project
« Reply #15 on: May 16, 2021, 10:43:34 PM »
Our posts crossed Nigel. Got to say your recommendation is a lot less elbow intensive 😊
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #16 on: May 16, 2021, 10:46:47 PM »
Pour boiling water down the carb slides to free them off .. they will be gummed up with old fuel that's turned to a varnish like substance.  Be careful with the rubber diaphragms though .. 'kin expensive to replace !
Offline BenPowell
« Reply #17 on: May 16, 2021, 11:03:40 PM »
Some of the parts aren't that bad, just some bits which are stained and a bit dirty from years of being sat, at least I’ve got a few methods to try, thanks again, always nice to get fast responses.
I will try the boiling water, is it worth trying to remove the diaphragms first? Probably could do to check them for damage.
« Reply #18 on: May 16, 2021, 11:04:49 PM »
An addition to above, using a domestic steamer (wallpaper etc) as some have a straight nozzle to clean ovens, are pretty effective on any oil fuel based gumming etc. Obviously heat capped at 100 degrees, they are safe and effective on most materials.
Offline Menno
  • www.tanklackieren.de
« Reply #19 on: May 16, 2021, 11:10:54 PM »
Ben and I also discovered today that 'Light Ruby Red' which looks like a solid colour is actually a white basecoat with candy red on top followed by clear coat.
(Attachment Link)
Whoever wrote this... it is incorrect.
Candy jade green for starters is bluemetallic with a candy yellow coat
Candy bacchus olive bluemetallic-orange
Or goldmetallic with bluecandy
Light ruby red is not a candy.
It is common to always paint a light layer like white or (what Honda also did) orange ground befor aplying red.
« Reply #20 on: May 17, 2021, 09:01:21 AM »
(Attachment Link)
It was American Honda Menno. Pretty comprehensive list and the first time I have ever seen the correct metallic dark grey ( Black metallic -XE) for the CD175A sloper ... Lave Grey Metallic (not to be confused with Audi Lave Grey ). But you are 'the man'..so I bow to your knowledge.
https://www.dropbox.com/s/gxoaq47jpzf21yi/Paint%20Honda.pdf?dl=0
« Last Edit: May 17, 2021, 07:45:10 PM by AshimotoK0 »
« Reply #21 on: May 17, 2021, 10:09:19 AM »
I always used to use Brillo pads with a dash of Solvol on them, works great on alloy as well.
Offline Menno
« Reply #22 on: May 17, 2021, 11:49:23 AM »
Thank you for that information, Ashley.
Very interesting read. Thanks again.
Offline BenPowell
« Reply #23 on: May 25, 2021, 10:23:44 PM »
Hi again everyone,
Tonight I decided to take a look inside the carbs which I removed the other day.
Based on the chrome and the rest of the bike being fairly clean I thought they wouldn't be too bad.  ::)
I've attached some images below, one of them looks okay and the other is pretty bad. Funnily enough the slide came out of the worse looking one, with some help from Ash.
Still got the other to get out, its been soaking in boiling water but so far no luck. Will have to keep trying.
Re the paint and chrome, solvol gave me some really good results on the rear mudguard with 0000 grade wire wool, Had a try with some multona black paint on various parts and really happy with the finish and look.
Offline mtrhead
« Reply #24 on: May 31, 2021, 05:43:39 PM »
Wow, that chrome has come up nicely. That inspires me to crack on and do some fettling on mine whilst I wait for Mr Silver's delivery
Sent from my SM-G973F using Tapatalk
Offline BenPowell
« Reply #25 on: June 02, 2021, 06:37:11 PM »
Yeah, I was surprised myself how well they cleaned up, took a bit of time but we’ll worth it, maybe a bit of room to improve them some more.
I just need to protect the underside of them now to stop them rusting from the inside out.
Pictures below before the elbow grease.  :D
« Reply #26 on: June 11, 2021, 03:03:39 PM »
(Attachment Link)
Menno.. we studied Ben's tank closely today and sure looks like a candy coat on top of the white base, as described in the Honda Bulletin I posted.
Offline Menno
« Reply #27 on: June 11, 2021, 09:32:22 PM »
If you would paint a candy red over white you would have to add so many layers to cover the white that the colour would become very dark.
But even still.... it is called light ruby red. Not light candy ruby red.
Offline BenPowell
« Reply #28 on: June 18, 2021, 12:14:29 AM »
Hi everyone,
Bit of a progress update on the CB350.
Been busy the last few weeks doing bits here and there, mainly painting things black and working on the carbs.
Finally, the carbs are at a point where all I need is a new seal kit, after going through each part and removing the varnished fuel, maybe one last clean before fitting to the bike, whenever that may be.
All the electrics have been removed from the bike, a few dodgy wires which will need some attention, but hope to test the loom at some point in the near future.
The engine is finally out of the bike, and ready to start stripping down, hopefully this Saturday, I did have a quick look under the cam cover, visually it looks really clean. Pic below. But I’m really keen to see what condition the bores and rings are in.
As always if anyone has any tips or tricks to add it is really appreciated.
Thanks everyone, hopefully will be posting some more stuff on Saturday for the engine strip down.
« Reply #29 on: June 18, 2021, 01:16:12 AM »
Interesting project & pictures.
