Author Topic: Primary chain and rubbers  (Read 2410 times)
« on: July 10, 2021, 09:15:40 AM »
Help needed please. I’ve seen lots written on this topic, but would appreciate some advice on an economic  source for primary chain, primary rubbers and cam chain.
Would also appreciate some advice on the can chain tensioner blade. I can’t make out if the blade should have chain run witness marks or if as new it should be flat.
Re: Primary chain and rubbers
« Reply #1 on: July 10, 2021, 10:42:42 AM »
Primary chain kawasaki, cam chain did, rubbers Honda.
That tensioner is fine unless the rubber is spliting off the ends
« Reply #2 on: July 10, 2021, 12:07:29 PM »
Thanks Bryanj. No evidence of splitting at the ends.
Cheers.
Offline Charlie J
« Reply #3 on: July 10, 2021, 01:30:00 PM »
I followed Bryan's advice and used a Kawasaki primary chain on my CB500 K1. Here's a link to the supplier I used.
https://www.motorcyclespareparts.eu/en/kawasaki-parts/920571011?currency=GBP&withvat=1&gclid=EAIaIQobChMIxZvMhMah7gIVyrTtCh39NQiJEAQYASABEgIWtPD_BwE
« Reply #4 on: July 10, 2021, 03:12:46 PM »
Hi, Oddjob. Really appreciate the insights and to be fair I’d already resolved to replace the blade. I’m not on too tight a budget and I won’t be ‘going in’ again.
I’d budgeted for primary, primary rubbers, cam chain and potentially new shells. I’ll also be replacing the main shaft bearings. The bores and pistons are ‘pristine’, but I’m refreshing with new rings and a head overhaul. The guides and valves are fine, though the exhausts are surprisingly heavily carbonised.
« Reply #5 on: July 10, 2021, 03:14:27 PM »
High Charlie J. Thanks for the info. That will save me a few Bob. Presumably the cB550 and CB500 primaries are identical?
« Reply #6 on: July 10, 2021, 03:28:18 PM »
Sound, thanks.
« Reply #7 on: July 10, 2021, 08:50:14 PM »
The grooves  are cut in by the chain sodeplates within a very short time the the rollers run on the rubber, i was trying to gauge how far the centre was below the outers and it looked negligible in the photo
« Reply #8 on: July 11, 2021, 07:39:57 PM »
I’d say this is shagged?
« Reply #9 on: July 11, 2021, 08:46:42 PM »
Furkled, crodged, burglered or any othe adjective you have
« Reply #10 on: July 11, 2021, 10:21:56 PM »
CB650 tensioner….is this a ‘bolt on’ or a fiddle?
« Reply #11 on: July 12, 2021, 07:34:01 AM »
Machining work plus the problem of finding one
« Reply #12 on: July 12, 2021, 08:01:38 AM »
Ok, thanks. New chain and leave as standard.
Blade, blade rubbers, primary rubbers, primary and camchain now ordered.
I’ve discovered that the rear 16mm engine mounting bolt doubles nicely as an improvised slide hammer to remove the primary shaft. But I’m guessing most on this forum already new that?
« Reply #13 on: July 12, 2021, 09:07:40 AM »
Anybody know where I might obtain the primary output shaft bearing part no 91002283000.
Part no34. Seems to be unobtainable?
« Reply #14 on: July 12, 2021, 06:12:51 PM »
Hi, oddjob. Thanks for that. The engine is in bits, lots of them. Amazing how much space a dismantled engine occupies. I’m reading those articles right now.
