Author Topic: New heart for the old girl  (Read 4135 times)
Re: New heart for the old girl
« Reply #30 on: August 29, 2021, 03:10:52 PM »
I used to swear by BPVF7 Ted, there were so many detergents in it that you could eat your dinner off the inside of the engine, that’s if you didn’t mind the taste of oil that is.
Yes, I think in the early days of good oil detergents some brands went a bit overboard!
On the old BMC A series engine the development of good positive crankcase breathing systems did stop a lot of engines gunking up.
Offline allankelly1
« Reply #31 on: August 31, 2021, 07:38:42 PM »
Hi all
Picked up cases tonight
Really please with them
A few up close pics
As you can see in the third pic the cleaning process is very kind/ gentle on the cases as you can still see the “exposed” original faces as the process will only remove oxidation and dirt.
Will next week get the barrels done so they are nice and clean ready to send out to be bored out to 460cc
Next job (now cases are back) is to record all the crank marking then mic up the crank and sort out all the shell bearings so I can do a plastigauge fit with the new shells and clean cases.  Then once I am happy I will paint the outsides and then start the reassembled of the bottom end
Also in parallel got my oil cooler kit in order so I can sort this out as a separate project on the on the road bike while I am awaiting parts for the “on the bench” engine build
Catch up soon
Best wishes Al
« Last Edit: September 01, 2021, 07:07:10 AM by allankelly1 »
Offline allankelly1
« Reply #32 on: September 09, 2021, 05:48:23 PM »
Hi all
Well that’s the planned oil cooler mounted
Was not a lot of space and needed to manufacture a bespoke mounting and remove a couple of mounting brackets on the oil cooler itself that were not needed
Also got the filter mount sandwich plate
Now just need to sort out some bespoke feed and return pipes and this part of the project is done
Will look very “cool” once finished with all the braided stainless hoses
Catch up again soon
Best wishes Al
Offline allankelly1
« Reply #33 on: September 09, 2021, 06:38:44 PM »
Hi Oddjob
Filter sandwich plate was from D & M Engineering
As for mudguard clearance loads of space and there is more risk of mudguard touching headers due to me fitting a generic mudguard from DS but got 40mm preload spacers fitted so front end is a bit firmer
Offline allankelly1
« Reply #34 on: September 09, 2021, 09:59:43 PM »
It’s not a replica exhaust but a stainless Delkevic system that comes supplied with the plain clamps
Fits a treat  and you also don’t need the split exhaust collets  either as the header pipe has a flange welder in place that the clamp used to seal the exhaust into the exhaust port
Also down pipes just slip into collector and held in place using springs and no clamps
Good value for money and sounds rather “rich”
« Last Edit: September 09, 2021, 10:05:31 PM by allankelly1 »
Offline philward
« Reply #35 on: September 09, 2021, 10:03:04 PM »
Some great engineering work there Alan - envious!
Offline allankelly1
« Reply #36 on: September 10, 2021, 05:20:16 PM »
Thank you for the
Yes very pleased as not much space to fit anything
It’s off next week to be anodised black and going to get the sandwich plated done in black too as the gold is a bit
Catch up soon
Best wishes Al
« Reply #37 on: September 10, 2021, 05:48:42 PM »
Thank you for the
Catch up soon
Best wishes Al
Nah keep a bit of bling Allan!
« Reply #38 on: September 10, 2021, 07:23:24 PM »
A really tidy looking bike Alan almost 'period' type mods👍
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline allankelly1
« Reply #39 on: September 10, 2021, 07:44:18 PM »
She certainly has come a long way in the last 18 months
Just need to drop in a rebuilt 460 motor and she is all done ( or maybe not) as there is always something else to tweak
« Reply #40 on: September 11, 2021, 11:19:21 AM »
I like the twin disc conversion but way too difficult for me as I'm still very much a novice and don't have your engineering skills. I agree with what's been said OK it's not original but is still period looking. I love to see the originality of personalization.
Offline allankelly1
« Reply #41 on: October 02, 2021, 08:13:54 PM »
Hi
Just a quick update on the thread
Planned oil cooler now all sorted
Sorting pipe runs was a bit of fun but a kit off eBay with all sorts of different end fittings sorted that
Looks the part and make the bike just a little different from the crowd
Now to start sorting new parts for the replacement motor
Catch up soon
Best wishes Al
« Last Edit: October 02, 2021, 08:17:03 PM by allankelly1 »
Offline smoothoperator
« Reply #42 on: October 02, 2021, 08:22:15 PM »
Some good looking engineering here Alan, looking forward to see how it develops with the new engine.
Steve
2017 Triumph Bonneville T100
« Reply #43 on: October 03, 2021, 11:08:06 AM »
Where did you find those lovely extra deep dome headed nuts on your manifold?
Offline allankelly1
« Reply #44 on: October 03, 2021, 11:10:04 AM »
Hi Ted
Rs components
They are stainless steel
I will take a look and see if I still have eight left but no promises
Best wishes Al
