Author Topic: Fork seals  (Read 928 times)
oldchuffer
  • Guest
Fork seals
« on: October 05, 2021, 05:02:12 PM »
Taken the forks out of my restoration project. The forks look in decent condition but i'd like to replace the seals, can it be done without dismantling the forks? Or would it be easier to dismantle? If so are there any pitfalls to watch out for?
Re: Fork seals
« Reply #1 on: October 05, 2021, 06:39:43 PM »
It can be done without dismantling but to be honest, as you've got the forks out, it's a really good opportunity to drain all the old oil and crud out which settles at the bottom, give the insides a really good clean out and rebuild. There's a post on when I did my 400 ones, I'll try and find it and post the link.
Now attached. You have to read the whole thread as panic stations snuck in at one time, re the orientation of the seals.
http://www.sohc.co.uk/index.php/topic,14717.msg120007.html#msg120007
« Last Edit: October 05, 2021, 06:44:24 PM by Nurse Julie »
Offline smoothoperator
Re: Fork seals
« Reply #2 on: October 05, 2021, 06:59:58 PM »
Just come back from the garage having started to try and dismantle the forks and by magic, this post appears. Good old Julie strikes again. My allen bolt is clearly rotating the whole unit it holds in so I stopped. It does say in the manual to leave the top nut tight to give spring pressure but it's hard to imagine this making much difference. I'll try with the impact driver tomorrow if I my allen socket combo fits. Fingers crossed or yet more tools needed. Went to collect some epoxy resin from the RS shop in Corby today as I am having a go at replacing the HT leads.
Steve
2017 Triumph Bonneville T100
Online Spitfire
Re: Fork seals
« Reply #3 on: October 05, 2021, 07:03:04 PM »
If I remember rightly when that happened with mine I took the top nut off and placed either a socket or a piece of tube in the leg and put the top nut back on, this held it enough to undo the bottom bolt.
Re: Fork seals
« Reply #4 on: October 05, 2021, 07:06:22 PM »
Now that sounds like a top tip.
Steve
Offline AndyD
Re: Fork seals
« Reply #5 on: October 05, 2021, 07:42:40 PM »
I've had a lot of luck using a slightly sharpened broom handle to bang into the fork leg and hold the internals tight enough to undo the allen bolt.
Always amazed it's worked and worst bit is the stinky old oil all over the handle afterwards
Cheers,
Andy
oldchuffer
  • Guest
Re: Fork seals
« Reply #6 on: October 05, 2021, 08:07:10 PM »
Thanks everyone. Useful link Julie, many thanks.
Re: Fork seals
« Reply #7 on: October 05, 2021, 08:35:27 PM »
It does make a difference and so does the impact gun, i used a 3/8 drive air gun
oldchuffer
  • Guest
Re: Fork seals
« Reply #8 on: October 05, 2021, 08:38:06 PM »
Unfortunately i do not have an impact gun. It might have to be the broom handle trick. Wish me luck.
Offline SumpMagnet
Re: Fork seals
« Reply #9 on: October 21, 2021, 06:54:35 PM »
I still use the broom handle method....which I first saw in the Haynes manual of all places, which advocatyed banging something similar in to jam the damper assembly if the spring didn't hold it.
CB750F2 - in pieces
oldchuffer
  • Guest
Re: Fork seals
« Reply #10 on: October 21, 2021, 08:00:43 PM »
Update: All completed using the "broom handle" method, it worked a treat. And yes, the old oil did STINK!
Re: Fork seals
« Reply #11 on: October 31, 2021, 04:54:46 PM »
Update. Bolts out using my impact driver. Garage now smells like Grimsby docks so I have abandoned it for a while. Sending fork tubes to Philpots to renovate.
Steve
