Author Topic: The rebirth of Lazarus  (Read 63801 times)
Re: The rebirth of Lazarus
« Reply #315 on: December 10, 2023, 03:06:17 PM »
Bleed the master before connecting pipe.
Wearing gloves put finger over outlet hole and pull lever in release and reaply finger let lever go and reapply, repeat till pressure is felt under finger then whilst lever is held in use your third hand to fit and tighten hose and banjo bolt then try blleding at caliper.
This can take a while but has never failed for me, also cover everything you dont want fluid on!
« Reply #316 on: December 10, 2023, 03:49:29 PM »
not much happening as I have been ill for a couple of weeks, but still struggling with the front brake bleeding. all new or refurbished, hoses rubber seals etc but just will not bleed. I have tried all the usual methods with syringes  but no luck so getting really frustrated, even dismantled master cylinder in case i did something wrong.
Hope you're feeling better Mick. Did you fit a new pressure switch?. The reason I ask is that we bought a couple from David Silver last year and they were faulty. Graham almost sent himself doolally trying to bleed a front brake, all new parts and refurbed like yours, he kept swapping parts again and again with no luck. When he fitted the old switch, it bled up instantly. He tried the DS switch again on another bike and the same thing happened again, the system would not bleed. .
« Last Edit: December 10, 2023, 03:51:26 PM by Nurse Julie »
Offline mickwinf
« Reply #317 on: December 10, 2023, 03:50:04 PM »
Hi Bryan I did try that method but didn't seem to build up any pressure.
Offline mickwinf
« Reply #318 on: December 10, 2023, 03:54:31 PM »
Hi Julie, am feeling a bit better until my garage roofing felt went AWOL in the wind last night! It's the original pressure witch so hope that's not it.
« Reply #319 on: December 10, 2023, 05:52:00 PM »
Try this Mike. Only really works with rubber hoses not braided.
Get a brake clamp or failing that a pair of mole grips, clamp the rubber hose near the joint at the bottom yoke, before the joint not after. Try pumping the MC now, if it's solid then the problem lies below where you've clamped, if not the force will tend to blow any airlock back through the MC, you'll see bubbles appearing in the reservoir. When it's solid move the clamp down to below the bottom yoke, test again.. If solid, the problem is in the caliper. Now release the pressure on the clamp until you can just about pump the lever, this will force fluid past the clamp but not allow it back up the pipe. In this way you can force the caliper to fill up, release the bleed nipple a little to allow any trapped air to escape.
Never failed to work but as I said an only be done with rubber hoses, never tried it with braided as I was worried it would damage the braiding, it may work though
« Reply #320 on: December 10, 2023, 06:33:05 PM »
If bleeding at the master gets no pressure you will never bleed the full system i have had it take over 30 mins of trying before first pressure and then more to squirt forcibly.
You my be better off with one of Mr Silvers repo ones
« Reply #321 on: December 11, 2023, 08:41:36 AM »
As already noted, but version of the mc bleed, with banjo disconnected at mc, lid off, fill with fluid and it should just run out of banjo port without any lever movement at all.
If it doesn't leak out like this with lever in "home" position, then unlikely to fill the line easily when bleeding.
Offline mickwinf
« Reply #322 on: December 16, 2023, 09:54:06 PM »
A couple of small victories today. The brake bleeding saga was solved by a new repro from silvers, still took a while but bled in the conventional way and a firm lever now. Also did a soldered repair on the tank, as the hole was only 2-3 mm it seems to be ok. De-rusting tank with phosphoric acid ready for paint, almost there!
Offline mickwinf
« Reply #323 on: December 21, 2023, 01:44:15 PM »
While de-rusting the tank it revealed several more small holes around the reinforcing area where the rear tank mounting is. I have soldered them but still getting a small leak from somewhere inaccessible so am going to use a liner. Not ideal but it's my only option.
« Reply #324 on: December 21, 2023, 01:56:29 PM »
Maybe safer when it’s a little “peppered” like that. Nothing more annoying than getting it all painted and finding further leaks!
1978 Honda CB550K3.
Offline mickwinf
« Reply #325 on: December 22, 2023, 09:54:46 AM »
the problem with the lining process is flash rusting before I can dry the tank out to line it. will try today.
« Reply #326 on: December 22, 2023, 10:47:42 AM »
Race between heat and rust!😳 Hot water flush might speed up the drying?
« Last Edit: December 22, 2023, 10:49:35 AM by Johnny4428 »
1978 Honda CB550K3.
Offline mickwinf
« Reply #327 on: February 06, 2024, 05:40:29 PM »
Some more progress, tank has been lined with a two pack liner and painted with a layer of clear, then the stripes applied. Will lacquer over in next few days and finish the side panels. Almost there!
Offline DomP
« Reply #328 on: February 06, 2024, 06:49:35 PM »
I used phosphoric acid to strip mine after first using electrolysis, it's meant to stop flash rusting.  I'll be honest I've not looked at it in a while😬
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline mickwinf
« Reply #329 on: February 13, 2024, 03:37:56 PM »
Exciting times, tank is painted and back on bike, one side panel has to be re done as I screwed it up. Some final things to do, chainguard is one of them as the original one is bent out of shape. I do have a 550 f chrome one but the chrome is beyond repair, but would paint up ok so might use that. Today I insured it so on the road soon!
