Author Topic: Honda CB400four crank/conrod color bearing game  (Read 590 times)
Offline eem46
« on: November 11, 2021, 07:12:16 PM »
Dear All, I would like your knowledge and advice on which color codes bearings these are:
And this is a different set of crankcases, than the rollerbearing marks (see other post)
Crankcase stamping BBCBB
Crank A1 B1 B2 B2 2
Conrods 2 3 2 1
So that makes for the crank: B1 B1 C2 B2 B2
Green Green xxxx Brown Brown, what is C2 crank?
Conrods: A2 B3 B2 B1
Yellow Brown, B2 and B1 are?
Please add and confirm the color
Thank you a lot
Kind regards,
Emiel
Offline Deano400
Re: Honda CB400four crank/conrod color bearing game
« Reply #1 on: November 11, 2021, 07:57:40 PM »
Crank
Green Green Black Brown Brown
Con
Yellow Brown Green Yellow
Offline eem46
« Reply #2 on: November 11, 2021, 08:04:00 PM »
Thank you very much! Kind regards Emiel
Offline Deano400
« Reply #3 on: November 11, 2021, 08:07:09 PM »
From the parts book.
« Reply #4 on: November 11, 2021, 11:45:44 PM »
You were probably thinking it anyway - I would use Plastigauge to check the final oil film thicness.
Offline eem46
« Reply #5 on: November 12, 2021, 03:31:50 PM »
Yes I will double check, first need to find a black crankcase bearings 😁
