Author Topic: 550 F2 started!  (Read 70209 times)
amx1992
  • Guest
Re: 550 F2 started!
« Reply #885 on: December 18, 2022, 05:44:34 PM »
I made a hydraulic clutch for my 400, using the seal from a hope master cylinder (10mm ish), and machining a cylinder and piston out of some aluminium. Worked really well and the clutch was really light, too light for me really. I ended up swapping back to cable with a bearing in the pivot.
I've just mocked it up so you can see roughly how it looked
[ Guests cannot view attachments ]       [ Guests cannot view attachments ]
Re: 550 F2 started!
« Reply #886 on: December 18, 2022, 08:18:57 PM »
Haven't had a chnce to read any of this yet but going to...not ignoring you all, looks fascinated but hard at it and havent had a 30mins sot to have a proper digest..............
thanks all
Re: 550 F2 started!
« Reply #887 on: December 18, 2022, 08:23:09 PM »
Nice work and overall concept am.
Yes you'd certainly get a potent ratio with that bore size, think you're right at 10mm or they may be 10.5mm. Probably from a mc like this one
Same concept by pulling but using a piston and seal from a caliper at 15mm (still with mc shaft seal though) and perhaps a coil spring in blind end of cylinder to help return piston and avoid holding force against clutch could be a development step.
Re: 550 F2 started!
« Reply #888 on: December 19, 2022, 08:55:13 AM »
Thinking that through  :) it's the other way round regarding ratio and slave bore size. Larger piston will give less travel and more power to accentuate how easy it is to operate.  Hope now make a smaller mc piston (9mm I think) in their 4 series brake system that may help, but with this of course adding to the bike's original ratios accumulated from the cam and cable lever effects built in .
You'll likely need the bigger sized piston if going straight to the clutch push rod as it will delete those leverage elements built in above.
Re: 550 F2 started!
« Reply #889 on: December 21, 2022, 07:28:56 PM »
Right…………exciting and hurried unwrapping commences
Re: 550 F2 started!
« Reply #890 on: December 22, 2022, 12:14:14 PM »
Hold on with the unwrapping - It's still 4 days until Christmas!
Re: 550 F2 started!
« Reply #891 on: December 22, 2022, 12:28:28 PM »
I have Andy
Well, proper chuffed with that!
It’s come out really nicely
Re: 550 F2 started!
« Reply #892 on: December 22, 2022, 12:29:09 PM »
Re: 550 F2 started!
« Reply #893 on: December 22, 2022, 12:29:37 PM »
Re: 550 F2 started!
« Reply #894 on: December 22, 2022, 03:04:04 PM »
Thought you were going for nut brown?????? I know you steered Ted away from it just so you could be the first  :D :D :D :D
Re: 550 F2 started!
« Reply #895 on: December 22, 2022, 03:06:31 PM »
Yup, nice job that- really smart..
Re: 550 F2 started!
« Reply #896 on: December 22, 2022, 04:08:33 PM »
Be running by boxing day
Offline SPR
  • 1972 500/4 K1
Re: 550 F2 started!
« Reply #897 on: December 22, 2022, 06:04:25 PM »
That looks excellent - going to be a cracking bike when assembled
Re: 550 F2 started!
« Reply #898 on: December 22, 2022, 06:37:54 PM »
I actually asked for beige! ;D
New levers came today, adjustable for length, span and the move up and pivot  rahher than snapping. I had them made by a pal abroad..really rather impressed TBH     The wheel rims and spokes came as well via Parcelfarce. I asked to have them delivered to the PO in the village  as I wouldnt be in so of course when I came home they were on the door step in the street being splashed by the tractors.......... surrounded by idiots! ;D ;D ;D
Re: 550 F2 started!
« Reply #899 on: December 22, 2022, 06:47:32 PM »
What colour is the frame Roo in some shots its looks pewter-silvery, some bits black - is it heat sensitive paint or an odd lighting effect ?
I knew I should have stuck to the colour that dare not speak its name " tun nworb"  ;D ;D ;D
