Author Topic: Honda CB500 Four tool tray .  (Read 4857 times)
Re: Honda CB500 Four tool tray .
« Reply #15 on: December 09, 2021, 06:58:19 AM »
This goes with the tool tray Ben .. so may be also worth considering printing.  :)
Offline BenPowell
« Reply #16 on: December 13, 2021, 12:20:48 AM »
Hi everyone,
I had some time tonight and I have drawn up the tool tray, still some small details to add but the tricky bits are done.
I will print off some 1:1 scale drawings to check the angles match and the shape is correct, hard to get exact measurements with thin moulded parts as they distort slightly.
If anyone is seriously interested in one of these 3D printed can you let me know, I won't spend to much more time on it if not. I'll need to add the finished file into the 3D print software to find out material usage and time to print etc.
Some images of the CAD model so far
« Reply #17 on: December 13, 2021, 08:22:40 AM »
Top work Ben  :)  .. I hope there is a good response on here after all of your hard work!
May be worth sharing on the CB500 four F.B, group    https://www.facebook.com/groups/40322702454
The part no. you are recreating is 83501-323-020
Offline mickwinf
« Reply #18 on: December 13, 2021, 09:03:01 AM »
I would definately have one if you make them, cheers.
Offline deltarider
« Reply #19 on: December 13, 2021, 11:38:18 AM »
Don't know if you have interest in copying it in detail, but know that 83501-323-020 originally had a small 'enclave' to accomodate spare fuses.
Offline BenPowell
« Reply #20 on: December 13, 2021, 11:48:22 AM »
I will be adding it in, should only take a few minutes, got holes and some supports to add as well.
Offline philward
« Reply #21 on: December 13, 2021, 01:39:14 PM »
I'd be interested Ben
« Reply #22 on: December 13, 2021, 04:41:40 PM »
I possibly might although Im not sure until crimbo when I've the heap on the ramp and start to take it to bits. What sort of money will you be asking for one or are you not too sure yet?
« Reply #23 on: December 13, 2021, 06:40:34 PM »
Is that for your F model ...I don't think the F's had that part.
« Reply #24 on: December 13, 2021, 06:49:17 PM »
It didn't Ash as the funnel for the air filter box got in the way so they removed it. Run it without the funnel though and the tray should fit ok, it's certainly better there than where they fitted the tools after though. Never saw the need for the funnel myself, possibly something to do with reducing induction roar.
Offline Seabeowner
« Reply #25 on: December 13, 2021, 06:54:36 PM »
And of course the separate bit that holds the mesh over the oval cutout will also add to the work. 83502-323-000
The tray looks awkward to print as there are bits above and below the tray. Presume it will need support pieces. Took a look at it here and decided against it.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
« Reply #26 on: December 13, 2021, 07:24:02 PM »
Someone was already printing those Seabeowner, can't remember who now though.
« Reply #27 on: December 13, 2021, 07:57:11 PM »
 Pf course, disreguard that last coment then ;D ;D ;D
Blonde moment :o
« Reply #28 on: December 13, 2021, 08:05:56 PM »
I think Richard on here  (RGP750) was casting them Ken not printing .. could be wrong though  :-[
Offline BenPowell
« Reply #29 on: December 13, 2021, 08:47:30 PM »
It will be a bit tricky without a doubt and certainly will need some support material, having said that I’ve done some awkward stuff for work so I’m willing to have a go at it. I have the separate part which holds the mesh on but will finalise it once I’ve got a tray printed, so I can make sure it is a good fit.
