Author Topic: Cant get it in!  (Read 2009 times)
Offline waffey
Cant get it in!
« on: January 27, 2022, 11:17:39 AM »
Hi,
i've put the crank back in ect, joined the two cases but am now d=struggling to put the shaft thru the primary drive clutch. Its a new primary drive chain off DSS. It's close to fitting but i just cant do it. Am i missing some thing? any tips or tricks?
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Honda CB400 F2 1977 (restoration underway)
Re: Cant get it in!
« Reply #1 on: January 27, 2022, 12:36:56 PM »
Perseverance is all i can say, everything has to be just right with a new chain
Re: Cant get it in!
« Reply #2 on: January 27, 2022, 01:01:18 PM »
Gently lever the primary drive back, protect the crankcase with a piece of wood or something whilst you do it. Because there is no slack in the chain it's difficult to get everything to line up, which means you have a really well made chain.
Re: Cant get it in!
« Reply #3 on: January 27, 2022, 02:03:34 PM »
I remember having issues when I fitted mine. It is a tight fit anyway and the angle has got to be spot on.
Re: Cant get it in!
« Reply #4 on: January 27, 2022, 05:18:30 PM »
Walk away, take a break and have drink. Wait at least 30mins. Try again and it will lot straight in. Least that’s what happened to me :D.
Re: Cant get it in!
« Reply #5 on: January 27, 2022, 05:40:21 PM »
Story of my life..
Re: Cant get it in!
« Reply #6 on: January 27, 2022, 05:50:07 PM »
Sometimes the chain links are not fully engaged on the crank gear so you cant get it back far enough to line up the shaft. A bit of wiggling will get the chain settled on the gear and then the shaft will slot in.
Wiggling it about works in a lot of other areas! 😳
Offline waffey
Re: Cant get it in!
« Reply #7 on: January 28, 2022, 07:40:06 AM »
Thanks all. I'll try again at the weekend. I should have more patience at my age but it seems to have disappeared along with my ability to keep my opinions to myself  ;D
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
Re: Cant get it in!
« Reply #8 on: January 28, 2022, 11:43:37 AM »
Other things that dissapear with age are
Belt length, always seems to shrink
Bladder capacity
Tolerance for numpties, especally jobsworths
Offline The Vicar
  • Been waiting so long for this to happen.
Re: Cant get it in!
« Reply #9 on: January 28, 2022, 12:00:44 PM »
After prostrate cancer 3 1/2 years ago it is not a problem that I even consider these days, dream occasionally!
1973 Suzuki TS125
1982 Honda XL250R
Re: Cant get it in!
« Reply #10 on: January 28, 2022, 02:29:43 PM »
When I was having my groundhog days with my crank casings the first two times no problem with fitting the shaft - the third time I had issues like you - i thought I would have to split the crank case yet again - as has been said if the chain is not sitting fully engaged on the crank it just will not go that last bit - in the end whilst holding the pimary gear and shaft I rotated the crank very slightly one way then in the opposite direction and it went in a dream - I had fitted new primary drive rubbers, gears and chain as well.
Re: Cant get it in!
« Reply #11 on: January 28, 2022, 02:32:58 PM »
Bladder capacity
Yes as a man gets older (with one exception) everything gets harder.
Re: Cant get it in!
« Reply #12 on: January 28, 2022, 03:09:19 PM »
Bladder capacity
Luckily everything is still in full working order, just need a few more prods on the starter these days. 🙄
Re: Cant get it in!
« Reply #13 on: January 28, 2022, 05:01:59 PM »
 ;D
Offline TrickyMicky
Re: Cant get it in!
« Reply #14 on: January 28, 2022, 11:51:18 PM »
Just approaching 75 yrs old, and if I take my tablets I can still just get my leg over.  BUT, it must have an electric starter!
