Author Topic: Clips  (Read 1799 times)
Clips
« on: March 06, 2022, 02:01:46 PM »
Is there a supplier that sells the intake rubber hose clips a bit cheaper than the usual suspects. As I need 12 in total it's a bit much paying £9 each (DSS). I notice the old trick of buying a cheap set from Cruzinimage and just keeping the clips is no more, they now also supply them without the clips.
Re: Clips
« Reply #1 on: March 06, 2022, 02:24:16 PM »
Re: Clips
« Reply #2 on: March 06, 2022, 03:17:37 PM »
Sorry. Just realised you are looking for 750.
Re: Clips
« Reply #3 on: March 06, 2022, 03:34:21 PM »
If you want identical you are stuck with DS, if  you want some to work try ebay item144108712644 I have used them on 550 and the are the correct width but need the ends cut off after tightening as there is a lot left (dremel with disc)
Re: Clips
« Reply #4 on: March 06, 2022, 03:38:07 PM »
I used these on my 400/4 they do a few sizes.
https://www.ebay.co.uk/itm/143540474102
Re: Clips
« Reply #5 on: March 06, 2022, 05:35:46 PM »
Not sure were you get 12 from  ??? There are two different sizes. Just BZP your old ones  ;)
Re: Clips
« Reply #6 on: March 06, 2022, 05:45:18 PM »
I haven't got any old ones, unfortunately it didn't come with any. 4*3=12. 8 on the intake rubbers and 4 on the airbox.
Sent from my Pixel 6 using Tapatalk
Re: Clips
« Reply #7 on: March 06, 2022, 05:58:47 PM »
4 x 17255-230-000 air box to carb
8 x 17255-300-010 carb to engine
As i said, two different sizes ;)
Re: Clips
« Reply #8 on: March 06, 2022, 06:00:11 PM »
Thanks Trigg I was aware of that. They are however still £9 each.
Offline Moorey
Re: Clips
« Reply #9 on: March 06, 2022, 06:25:06 PM »
    Try doing a search on turbo clamps Roy there are quite a few different types.
Re: Clips
« Reply #10 on: March 06, 2022, 06:48:50 PM »
The 500/550 uses the air cleaner clamp number Roy, I may have some lying about. I don't use them on mine as I prefer using stainless steel clamps these days. I'll have a look. I seem to recall they are bigger than the insulator clamps.
Offline haynes66
Re: Clips
« Reply #11 on: March 07, 2022, 04:32:54 PM »
i came across these the other day.  ebay no  370476746124.  not sure if they are any good
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline rbt1548
Re: Clips
« Reply #12 on: March 08, 2022, 09:27:05 AM »
What about these?, they seem to do various sizes and not too badly priced.
I am not sure of the band width as I am not near my bike at present.
https://www.westfieldfasteners.co.uk/HoseClip_Mikalor_Supra-W4.html
Re: Clips
« Reply #13 on: March 08, 2022, 10:43:14 AM »
Mikalor clamps are too wide  ;) And jubilee clips cut in to the rubbers .
Re: Clips
« Reply #14 on: March 08, 2022, 06:12:00 PM »
DSS were charging £9 each for these clips last week they now want £12 each. These bikes wont be worth restoring soon if these price rises continue.
Honda CB750K5 FOUR 1975 USA Inlet manifold rubber to cylinder head securing clamp - Parts For Honda Motorcycles - David Silver Spares
