You could use let petrol and don’t have it so high in the aux tank, just reduce the head. Weight so to speak? Might be squeezing it passed the valve???Sent from my iPhone using Tapatalk
Cheers, Oddjob, suggestions have got me to a semi decent running condition. Bit more to do though but at least it idles at just under 1.5krpm and starts straight away. 👍I think I may have a problem and hope it's not a major one.I've been adjusting the clutch position and moved the kickstart lever out of the way. This morning I tried the kickstart and worked straight away.But just now after working on the clutch I tried again and heard a little click. Now the kickstart just spins.Has something come undone / off and do I need to worry and break open the engine? The lever spring returns the lever but it won't crank.the engine - I can only feel the return spring.Checked the clutch and it looks to engage/disengage. The rear wheel spins in 1st gear but I can stop it with my foot when I disengage the clutch.The kickstart is supposed to work with the bike in N and clutch engaged.
