Author Topic: Gasket paper instead of gaskets  (Read 1123 times)
Offline billdn
« on: April 07, 2022, 04:23:39 PM »
I have some left over gasket paper, any problems with using it for the gasket for the sump pan and Air breather box on top of the rocker box. ?
Re: Gasket paper instead of gaskets
« Reply #1 on: April 07, 2022, 05:07:51 PM »
I doubt it, I would but somebody will say otherwise no doubt ;)
Its the Yorkshire in me!
Offline TrickyMicky
« Reply #2 on: April 07, 2022, 05:23:28 PM »
Just make sure it is the correct thickness, we've all heard how particular Mr Honda can be with the precise length of some bolts!!  Take your time when marking/cutting out round some of the bolt holes, on some casings the amount of "land" round the hole can be quite narrow.
Offline billdn
« Reply #3 on: April 07, 2022, 07:31:43 PM »
Hmm, didn't keep old gasket and not sure of thickness. Maybe play safe.
Thanks.
Online Oddjob
« Reply #4 on: April 07, 2022, 08:59:27 PM »
Just ask someone to measure what thickness they are Bill. Might as well use it up and save some money at the same time. I've found all the bolt holes are 5mm deeper than the screw/bolt specified by Honda. 32mm bolt hole will take a 35mm bolt with no problem.
« Reply #5 on: April 07, 2022, 11:30:47 PM »
If its a 750 fine, if a 500/550 they are O rings anyway
Offline billdn
« Reply #6 on: April 08, 2022, 08:50:08 AM »
It's a 400/4 Bryan  ;).
« Reply #7 on: April 08, 2022, 09:30:07 AM »
I have a feeling they are also O rings
« Reply #8 on: April 08, 2022, 11:24:32 AM »
The 400f sump gasket is a thick waxy gasket. I don't think a thin paper one would seal very well and easily broken.
The breather cover is a normal paper gasket and would be easy to make. The o-ring seal is for the cam cover.
Offline mike the bike
« Reply #9 on: April 08, 2022, 11:18:34 PM »
I bought a set of hole punches to make the holes. Best to use a bit of ply or hardwood to punch against.
« Reply #10 on: April 09, 2022, 10:05:55 AM »
Here's a video of how to make them:
https://youtu.be/KJAgMhUOU-8
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
