Author Topic: CB650 wheels  (Read 2335 times)
Offline Maxcaddy (Nighthawk)
CB650 wheels
« on: May 24, 2010, 05:32:23 PM »
Would any of you good folks know if wheels from a later Honda or anything else, that would take a radial tyre, can be easily fitted (to a '83' SC-C), especially the back wheel  :) ?.
Ideally keeping the twin discs up front and drum rear, but not absolutely so  ;D ?
Many thanks
MC
Offline pae
    • Phil's CB650 pages
Re: CB650 wheels
« Reply #1 on: May 24, 2010, 09:06:50 PM »
Hi and welcome. Can't help on the wheel question though,
regards, Phil
Re: CB650 wheels
« Reply #2 on: May 25, 2010, 05:56:57 AM »
Radial or crossply both fit same size rims so dont understand the question
Re: CB650 wheels
« Reply #3 on: May 25, 2010, 06:59:39 AM »
Your bike has Comstar wheels (at least the one in your avatar has) so tubeless tyres should be OK. As Bryan says. radial or crossply - your choice.
2022 Tiger Sport 660
Re: CB650 wheels
« Reply #4 on: May 25, 2010, 01:26:12 PM »
That's good news :).  So what size radial tyre would you recommend fitting to a 2.5x16 rear rim then ?
Re: CB650 wheels
« Reply #5 on: May 25, 2010, 01:49:48 PM »
The issue with these old Hondas is that there is limited clearance between the swingarm for wider tyres.
Check out the ones you have fitted now and see how much extra you could fit in.
Wider tyres don't necessarily mean better handling though - these bikes were designed for skinny...
Re: CB650 wheels
« Reply #6 on: May 25, 2010, 01:58:46 PM »
Thanks, but it's not the clearance thats the limiting factor, its finding a radial that goes on a 2.5" rim.
The minimum rim for most (all ?) rear radial tyres is 3.5".  Hence the question, what other wheels fit ?
Re: CB650 wheels
« Reply #7 on: May 26, 2010, 05:45:46 AM »
Clearance is the limiting factor cos if you do find a 3.5 rim wheel that fits and get a tyre to fit it will rub on the swing arm cos it aint wide enough.
Q why radial, personaly i dont think they are worth it on a limited power and handling bike like the 650
Re: CB650 wheels
« Reply #8 on: May 26, 2010, 09:43:19 AM »
Understand where you're coming from, but looks to me as if Radials in 130/80 will fit, a 140/80 should fit, and a 150/70 could fit, depending on wheel offset, and that's without modding the swinging arm, which as it is so long is desperately calling to be braced  :)
A,  Sorry, but disagree, in my experience Radials can transform the handling of a number of 80's bikes.  OK with those long leading axle forks its never going to be a VFR, but that standard 16" comstar back wheel and x/ply tyre setup is lethal, especially in the wet.  That is, unless crossply's have come on a heap in the last 7 years   :-[.
Anyway, no worries, I'll take my trusty engineers rule to a couple of meets and see what I can size up  ;)
MC
