Alex the standard measurements are between 0.00079 and 0.00181 for both crank and rods.
A couple are close to the max 0.0018 but are still within range, just.
According to my calculations the difference between each shell colour is roughly 0.0004.
So crank 1 is .0016, if you fitted a brown in there it would be .0012 and with a black .0008. So black would be right on the edge of giving a minimum clearance so I'd go with brown in that journal although black would probably mean within range much longer.
No2, brown again
No3, I'd leave green.
No4, brown, again you could consider black
No5, brown.
Rods.
No 1, Green are ok.
No2, green
No3, Brown or even black. Black would give 0.0009 which is tightish but acceptable.
No4, Brown.
