Other Stuff > Desperately Seeking!!
NGK xd05f spark plug caps
Yoshi823:
I bought my ones for my FJ1200 from B&C Express
https://www.bandcexpress.co.uk/buy/NGK-XD05F-NGK-Sparkplug-Cap/XD05F.251#eq1
On my CB750F2 & my CB550s I used these angled ones for #1 & #2 cylinders & the long straight ones for cylinders #2 & #3
Inside of the plug caps there's a 5k ohm resistive element that can go open circuit. I've had this situation on my Exup1000. So I replaced the faulty element with a length of brazing rod & they're good to go ;)
smoothoperator:
--- Quote from: Oddjob on May 22, 2022, 10:14:54 PM ---https://www.brandedbiker.co.uk/shop/ngk-vd05f-motorcycle-spark-plug-cap-black/
Are these them?
--- End quote ---
No that's the vd05f. I got mine from there, they refunded my order for the xd05f after 6 months of being on order as they didn't know when they would get any more stock.
Sesman:
There are some serious supply and manufacturing problems at NGK. Next official import of XDO5F plug caps is June.
Oddjob:
Oh those, the long 90 degree ones commonly used on the outside cylinders.
Found 2 black ones of those yesterday, they are genuine NGK as they are far too old for them to be copies.
I could test them for resistance if you like, in case your supplier lets you down.
A little tatty but I'm reasonably good at tidying things up so they may be ok.
Sesman:
Thanks oddjob, that’s very generous of you, but I’ll pass and leave them for a more needy cause. I have some good used items, but I’m tidying up the 500 to match the refurbished coils.
I bought a set for the 550 last year from Greenspark with no issues whatsoever. I understand it’s the post pandemic supply Vs demand and material availability problems. I suspect they are made in China, so maybe that’s an additional issue.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
