Author Topic: Number will not firer  (Read 1376 times)
Offline Harrier want to be
« on: May 22, 2022, 08:14:53 PM »
I have changed the coil plug and cap but will number 2 won’t firer
When I take the plug out there is a spark
Any ideas please
Re: Number will not firer
« Reply #1 on: May 22, 2022, 08:24:11 PM »
Is the plug wet?
Check petrol in the float chamber,
Check the jets are clear in the carbs,
Try swapping one of the plugs that does work,
And fit the dead plug in that cylinder
Occasionally, you can get an iffy plug
« Reply #2 on: May 22, 2022, 08:57:38 PM »
What type of plugs are you using? Are they all old or new? What type of plug caps are fitted? Swap the plugs as John suggested, if no different, do a compression test.
« Last Edit: May 22, 2022, 09:01:23 PM by Nurse Julie »
« Reply #3 on: May 22, 2022, 09:28:45 PM »
Is the plug wet?
I have done all of the above , compression is good , plug is new , coil is new changed cap
Plug is wet ?
« Reply #4 on: May 22, 2022, 09:51:01 PM »
Is the plug wet?
Plug is wet ?
Wet with petrol,
« Reply #5 on: May 22, 2022, 10:49:28 PM »
Yes
« Reply #6 on: May 23, 2022, 12:34:03 AM »
You will know the expression if there is fuel, compression & spark at the right time the cylinder should fire.
Is it a nice strong spark or could it be failing under load?
« Reply #7 on: May 23, 2022, 01:34:54 AM »
I’m betting number 2 carb is flooding and causing the cylinder not too fire as there is just too much petrol in that cylinder. Try taking the plug out of no2, turn off the petrol, leave it for a day or so to allow for any excess petrol in the bore to evaporate and without turning on the petrol refit the plug and see if it starts then.
If it does you know it’s carb related.
« Reply #8 on: May 23, 2022, 06:39:28 AM »
Thanks I will give that a try
« Reply #9 on: July 29, 2022, 11:12:27 PM »
It turned out the carbs were so out of sync that number 2 wasn't  sucking
