Author Topic: 550F2 not firing on cylinders 1 & 4  (Read 397 times)
Offline Rolfbulmer
« on: July 19, 2022, 04:30:11 PM »
So it was with great delight that I started the engine for the first time today - brilliant it sprang into life. But before I could really congratulate myself I discovered that cylinders 1 & 4 were not firing.
I have done no investigative work yet. Was wondering if anyone could give some tips on the most likely cause and the order and best way to start checking things please.
PS the engine was run 'remotely' with the bare minimum wiring required.
1977 Honda CB550F - Cafe racer project bike
2001 Honda Hornet 600  - All weather bike
2019 Triumph Speedmaster 1200 - Dry and sunny weather bike
Re: 550F2 not firing on cylinders 1 & 4
« Reply #1 on: July 19, 2022, 04:40:18 PM »
1 & 4 are fired by the same coil so first place to look is the 12V feed from the points to the coil.
2022 Tiger Sport 660
Offline Rolfbulmer
« Reply #2 on: July 19, 2022, 04:46:04 PM »
Thanks for the reply.
Simple lad that I am, how can I do this test, bearing in mind the bike has no ignition and battery.
« Reply #3 on: July 19, 2022, 05:05:06 PM »
Inspect very carefully the assembly of wire on the 1/4 points as none of the metal components should touch the base structure of the points at that place.
The bolt and the wire tabs should all be insulated by fibre washers to prevent this happening, any missing fibre or the tabs bent such that they are touching the points baseplate and the system won't fire.
Check through carefully and compare to 2/3 to see if any obvious problem is there.
Also that both coils have a positive feed from the battery definitely in place.
