Author Topic: CB500 number plate / light bracket 84701-323-600B  (Read 976 times)
Offline SPR
  • 1972 500/4 K1
« on: August 06, 2022, 08:14:38 AM »
Morning
Looking fot a good CB500 number plate / light bracket 84701-323-600B
Simon
Re: CB500 number plate / light bracket 84701-323-600B
« Reply #1 on: August 06, 2022, 08:26:38 AM »
The UK CB750K2 was the same part and i am not sure but, Bryan J may be able to confirm if the UK CB500T was the same and is much easier to find.  ;)
« Reply #2 on: August 06, 2022, 11:05:05 AM »
There's also a US chrome version in both 3 hole and 4 hole.
« Reply #3 on: August 06, 2022, 11:19:19 AM »
Dont know if T is same but easy to check on cmsnl, i think Trigger will confirm 750 will fit but is very slightly different as 500 has a pressed raised bit on the horizontal black bit
« Reply #4 on: August 06, 2022, 11:54:20 AM »
The UK 500 four and the UK CB750 K2 are the same part and part number Bryan. I did have a lookie at CMS but, they only list 500T's for the USA market mate  ;)
« Reply #5 on: August 06, 2022, 12:47:29 PM »
CMS do but they do show the US 4 hole version also being fitted to the 500K. So it's more than possible the holes match up, it's the design of the plate holder that differs.
Offline SPR
  • 1972 500/4 K1
« Reply #6 on: August 06, 2022, 02:15:01 PM »
Thanks guys ... at least I can widen the search CMSNL have it listed at an eye watering amount of money
Online 3scs
« Reply #7 on: August 06, 2022, 05:55:44 PM »
Not quite sure what this is off it was fitted to my 550k3 when I bought it if it’s any use
« Reply #8 on: August 06, 2022, 08:14:40 PM »
As its chrome may be US model and might use the huge later rear light like the 750F2
« Reply #9 on: August 06, 2022, 09:04:11 PM »
That should fit. Both the smaller and larger rear lights are spaced the same bolt hole wise Bryan so they'll both fit.
I've got a brand new chrome one somewhere.
Offline SPR
  • 1972 500/4 K1
« Reply #10 on: August 06, 2022, 09:08:45 PM »
Sent you a pm
Offline SPR
  • 1972 500/4 K1
« Reply #11 on: August 06, 2022, 09:09:16 PM »
Great info - thanks !
Offline SPR
  • 1972 500/4 K1
« Reply #12 on: August 06, 2022, 09:52:09 PM »
Was doing a little research and found it is the same bracket as a GL1000 and found one on eBay.ie
Looks pretty rust free and the number plate bracket part especially seems to still be smooth with just surface rust ...
Better than the £300+ for a non original :)
Simon
