Author Topic: Bench Polishers  (Read 1712 times)
Bench Polishers
« on: September 02, 2022, 02:45:33 PM »
I'm seriously thinking of buying myself a bench polisher but am a tad overwhelmed by the many brands & specifications on the market. Is there a minimum power requirement I should look for is 370w enough?
Does this look about right?.
 https://www.ebay.co.uk/itm/274513815513
As is the way I gave my last bench grinder away many years ago to someone who would use it - it was a really heavy one I bought from a garage sale.
Re: Bench Polishers
« Reply #2 on: September 02, 2022, 03:45:27 PM »
Thanks Ken tbh I thought the power was probably on the low side at 370w.
So is 150mm polishers okay or is 200 better?
« Last Edit: September 02, 2022, 09:59:04 PM by McCabe-Thiele (Ted) »
Offline Matt_Harrington
Re: Bench Polishers
« Reply #3 on: September 03, 2022, 09:56:07 AM »
Ted, believe it or not, my Clarke polisher (bench grinder) is 210W. I use either 150mm 3M wheels (scotch brite etc) and 150mm polishing wheels on it. Yes, it slows with lots of pressure but I tend to take it slowly. I use it for cleaning up nuts & bolts an polishing S/Steel fabricated parts. If I was polishing large items, I'd probably go up to 8inch and a more powerful unit.
Re: Bench Polishers
« Reply #4 on: September 03, 2022, 02:42:36 PM »
I started (and still have and use) a 370w bench grinder. It was useful to learn the tricks etc but as soon as you're doing a lot of polishing or polishing steel for instance or even large alloy pieces it's limitations soon became apparent. I have it fitted with finishing mops now and use it to clean items of soap as I'm working with the more powerful Sealey.
I'd go 8" if I was you. The bigger the area of the mops the more access to the piece you can gain. The rats tail extensions make polishing FAR FAR easier and changing mops is now very easy.
Re: Bench Polishers
« Reply #5 on: September 03, 2022, 06:17:07 PM »
Rats,tail…do tell.
Re: Bench Polishers
« Reply #7 on: September 03, 2022, 06:42:39 PM »
Now now Ken don't be unkind to Rats.
Thanks for the links.
Online Laverdaroo
Re: Bench Polishers
« Reply #8 on: September 03, 2022, 06:55:27 PM »
You told me they were called pig tails Ken........And Julie agreed! Have I missed summut? :D
Re: Bench Polishers
« Reply #9 on: September 04, 2022, 02:06:31 AM »
Yeah you’re right Roo, mixing up my animals, pigs tails makes more sense
Online Laverdaroo
Re: Bench Polishers
« Reply #10 on: September 04, 2022, 01:22:00 PM »
Not enough coffee first thing mate, easy mistake to make ;D ;D
Re: Bench Polishers
« Reply #11 on: September 04, 2022, 01:25:38 PM »
Thanks for everyones input - Ive ordered a bench polisher from these guys.
The shafts could be longer but I think it will do the job rated at 750w.
.https://www.warco.co.uk/polishers/302989-bench-polishing-machine.html
Online Laverdaroo
Re: Bench Polishers
« Reply #12 on: September 04, 2022, 01:32:08 PM »
Y9u had a bonus Ted prmet ypur target this month on the domestic front, youre spending some brass, good man ;) :D.
Re: Bench Polishers
« Reply #13 on: September 04, 2022, 02:45:09 PM »
No pockets in Shrouds Roo.
Online Laverdaroo
Re: Bench Polishers
« Reply #14 on: September 04, 2022, 03:01:18 PM »
You star, crack on mate, my sentiments exactly! 8)
