Author Topic: NE gasket set, do I need thicker o-rings?  (Read 2310 times)
Online SteveW
« on: October 20, 2022, 03:56:59 PM »
Just doing the base and head gaskets on my 650. Got a gasket set from Silvers NE brand.
Wasn’t there something on here a while ago about using slightly thicker o-rings instead of those in the kit?
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: NE gasket set, do I need thicker o-rings?
« Reply #1 on: October 20, 2022, 04:49:24 PM »
Original gaskets contained asbestos and because that added strength were thinner, idealy a slightly thicker O ring at the head gasket would be better with new stylr thicker, non asbestos gaskets.
Online SteveW
« Reply #2 on: October 20, 2022, 06:50:42 PM »
Thanks Bryan, the existing o-rings are 5 x 2.4. Would 5 x 3 be okay?
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline Seabeowner
« Reply #3 on: October 20, 2022, 07:20:22 PM »
Hondaman suggested an imperial size I think that I converted and noted down as 5.6 x 2.38mm. The actual oil feed channel I measured as 4.83mm.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Online SteveW
« Reply #4 on: October 20, 2022, 11:01:44 PM »
wouldn't I need thicker than the standard 2.4mm?
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #5 on: October 21, 2022, 12:05:21 AM »
It all depends on the thickness of the gasket so, measure it up and work the size out  ;)
Offline Seabeowner
« Reply #6 on: October 23, 2022, 04:15:50 PM »
Going back to this that O ring appears to be 7/32 x 3/32. And not terribly different from the 5 x 2.4 mm that is on the p/l. Just measured a few bits. The location in the top of the block (two old blocks) 1.11mm and 0.99mm (perhaps that ones been skimmed). Three old removed head gaskets (probably all aftermarket) 1.23mm, 1.24mm, 1.29mm. Two new head gaskets, 1.24mm, 1.09mm.
How much do the gaskets compress, how much do the relax when remove, who knows?
So quite a range. Taking the max location depth and the max head gasket thickness would be 2.4mm!  Best case would be 2.08mm
There are many intermediate sizes available, so and 2.4mm looks not enough, but it is often the source of leaks if you don't get it right.
Online SteveW
« Reply #7 on: October 23, 2022, 06:53:27 PM »
Measured my original head gasket today and bang on 1.2 mm. new head gasket measures 1.29 mm so I’m thinking of using a 5 x 2.5 o-ring instead of the 5 x 2.4.
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #8 on: October 23, 2022, 09:13:04 PM »
Was the original unused or used?
Online SteveW
« Reply #9 on: October 23, 2022, 09:45:35 PM »
Used.
Bugger, just realised. More confused than ever now.
« Last Edit: October 23, 2022, 10:10:57 PM by SteveW »
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #10 on: October 24, 2022, 12:39:07 AM »
I have a brand new unused head gasket, genuine Honda, for the Cb500K, I could measure that if it helps.
« Reply #11 on: October 24, 2022, 07:08:21 AM »
Depends how oldit is Ken, supposedly thickness changed when asbestos was removed and that was some time ago
« Reply #12 on: October 24, 2022, 09:49:10 AM »
It's an original Honda one Bryan, full top end kit, in that green flat packaging they used to do back in the 70s. I have 2 of them IIRC plus a couple of the bottom end kits as well. I also have a couple of aftermarket kits lying around, must see if there is a difference in between the 2 head gaskets whilst I'm up in the loft, can't recall whose makes the other kits are but Noburo or something sounds familiar. Kits are 40 years old now.
Online SteveW
« Reply #13 on: October 24, 2022, 11:39:21 AM »
If you don’t mind that would be great. Thanks
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
Online SteveW
« Reply #14 on: October 24, 2022, 08:15:27 PM »
I've just measured the new o-rings in the new gasket set.
The originals are 5 x 2.4 mm, these are 5 x 2.0 mm. So with the gasket being 0.1 mm thicker and the o-rings 0.4mm thinner that's 0.5 mm under size.
I'm not risking fitting these 0-rings, I'm ordering some 5 x 2.5
« Last Edit: October 24, 2022, 08:37:59 PM by SteveW »
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
