Hi just a couple of easy checks, maybe swap the plug with#4 and also drain the float bowl and measure, mine are all about 50ml. I used a cheap plastic water dispenser cup marked at 50ml, the petrol melts everything else plastic!Ash’s excellent tip correctly says to drain tubes first for absolute accuracy, but a straight drain still gives an approx measure.
Seems to confirm no fuel flow through that idle jet, which ultimately means clearing it. These can unfortunately (similar for any small flow jets on most carbs) require a few times cleaning when getting them going again. Frustrating, but often typical as any small amount of debris from anywhere in the system can get stuck in such small openings.You could try firstly winding the air adjustment screw fully inwards while running it (gently) until it has no air supply (essentially the same as putting your hand on the carb, but just for the idle circuit) to see if anything soft that's restriction in there will get going again. Otherwise it's pulling at least that jet and also blowing through the associated air passage to bring it back to fully operational.OK Ill try all that. Thanks
