Author Topic: Best solvent for final cleaning prior to painting crank cases ?  (Read 583 times)
« on: November 11, 2022, 12:01:25 PM »
When I painted my 400 I brushed the crank casing surfaces with thinners, used clean absorbent paper to dab off any dirt that appeared then a final coat of thinners - when dry I Rattled Caned them - then air dried only. This time I plan to oven bake as per the paint instructions.
I have it in my mind that someone on this site mentioned using brake & clutch cleaning fluid instead  - I have a 5 litres can of that if it's better in some way ?
Re: Best solvent for final cleaning prior to painting crank cases ?
« Reply #1 on: November 11, 2022, 12:16:03 PM »
Acetone?
« Reply #2 on: November 11, 2022, 12:45:58 PM »
Should be ok ted as you already got it
Offline gary123
« Reply #3 on: November 11, 2022, 01:16:14 PM »
I had my cases acid dipped and then a used brake cleaner to remove any potential greasy fingerprints.
« Reply #4 on: November 11, 2022, 01:31:35 PM »
I've also got Cellulose Thinners so looking for the best option.
I'm thinking Thinners has the lower flash point so may leave less residue?
« Last Edit: November 11, 2022, 01:57:40 PM by McCabe-Thiele (Ted) »
Offline Matt_Harrington
« Reply #5 on: November 11, 2022, 04:15:29 PM »
Acetone or Thinners are my choice....
Offline heli_madken
« Reply #6 on: November 11, 2022, 11:40:01 PM »
Automotive panel wipe doesn't leave any residue behind and is made specifically for this task
