Mornin' folks,
This bank of carbs I've just about finished (believed 72-73 CB500) has large holes in the alloy mounting plate for the flex fuel pipes to go through towards the head, originally to connect to the double outlet tap. My tap has only one outlet so I've fitted a brass Tee piece. Double outlet taps seem unavailable, even though they could be dismantled, i.e. not rivetted, so I'm wondering if 3&4 are likely to suffer starvation at WOT with this set-up.
Is everyone using the same set-up?
Ian
