Author Topic: Spare calliper  (Read 1879 times)
Re: Spare calliper
« Reply #15 on: January 28, 2023, 11:20:26 AM »
Yup, my thoughts exactly Ted ;D
Re: Spare calliper
« Reply #17 on: January 28, 2023, 11:23:37 AM »
Thanks, like I say, never come accross anything like this befire as I simply haven't had to so all new to me. It's something similar like that I'm sure.
Re: Spare calliper
« Reply #18 on: January 28, 2023, 11:28:50 AM »
There's two different shape inside the caliper (those you have here) are single or double flare type.
Taper, like a funnel shape, used on virtually all bleed nipple to close off simply against that same taper on the nipple. Can also use "double flare" hard brake pipes without mod, most car caliper are like this for both ports.
Single flare pipes require the inverse in calpier to seal, so protruding funnel shape.
They may have made the original with removable "funnel" shape to facilitate use as double disc as you'd have to swap input with bleed to keep the brake lines symmetrically designed,  or you'd get one caliper with bleed front orientation and one rear when paired.
Re: Spare calliper
« Reply #19 on: January 28, 2023, 11:35:06 AM »
This type of arrangement
Re: Spare calliper
« Reply #20 on: January 28, 2023, 11:36:56 AM »
Soisit best to persue trying to find one orfar simpler to find another caliper in your experience? Litttle bit out of my comfort zone TBH so need all the advice I can get on this one. Happy tosppend the cash on one but would rather save a bit if there's an alternative.
Re: Spare calliper
« Reply #21 on: January 28, 2023, 11:40:57 AM »
That completely fts with my mental imageof ehat I thought I saw in the good caliper. Great picture, Thanksfor that,I always used loads of piccies when teaching, far easier to grasp than a randome description. cheers.
Re: Spare calliper
« Reply #22 on: January 28, 2023, 11:45:15 AM »
Excellent illustrations K2-K6 -  as always a picture paints a thousand words.
Re: Spare calliper
« Reply #23 on: January 28, 2023, 11:58:37 AM »
Isnt it, I was getting a bit convexly , double flared about it in my head., that piccy completey backs up my initial findings and thoughts 100% :)
Re: Spare calliper
« Reply #24 on: January 28, 2023, 11:58:57 AM »
You'll need more input from Bryan, Ken etc on Honda's parts type than I can give, or others that have previously done it.
I make up the pipes to suit things I'm working with using a flare tool but you've already got that fitting which you need to match on recipient part.
Re: Spare calliper
« Reply #25 on: January 28, 2023, 12:01:11 PM »
I stole it from the MG Owners club website by way of stealthy clip of their image  ;D
Re: Spare calliper
« Reply #26 on: January 28, 2023, 12:02:39 PM »
Just to confuse you more whilst the pipe is the same size metric and imperial flares are different especially where thenut pushes on the pipe, just going in garage to look for an easy one to find Roo
Re: Spare calliper
« Reply #27 on: January 28, 2023, 12:09:28 PM »
Fair do's and thankyou. It seems a shame to bin a caliper for the sake of a tiny insert but if it's not available then that might have to be the case. At least I've grasped the info which is half the battle. Top info as ever, thankyou., :)
Re: Spare calliper
« Reply #28 on: January 28, 2023, 12:14:24 PM »
This is what I’ve got Roo! A bit disappointed don’t seem to have the rear of Caliper or the bolts.
1978 Honda CB550K3.
Re: Spare calliper
« Reply #29 on: January 28, 2023, 12:14:58 PM »
It's probably not appropriate as you've already bought the hard connectors Roo, but the banjo arrangement for anyone doing this may offer solution that's intrinsically neat to get the line in with whatever flare exists
This a bicycle one (couldn't find a decent photo of motorcycle detail) that has the outer surface of the hole finished to accommodate banjo and copper washers to seal without flare interaction.
Many rear caliper use this type (moto-X particularly) as its low profile and less likely to snag and damage the pipe in use. Same as master really.
Can also be used with two pipes (slim banjo in pair at mc) right the way through and no joints etc.
