Author Topic: Carb bench sync  (Read 427 times)
Carb bench sync
« on: March 14, 2023, 03:51:15 PM »
With the idle screw right out, and ready to set Not 2 as a bench mark, someone on here said an eighth was too much as a guide and to use a sixteenth. Is this correct? Or is it just more critical to just get them all the same.
1978 Honda CB550K3.
Re: Carb bench sync
« Reply #1 on: March 14, 2023, 03:53:55 PM »
It's more critical to get them all the same John and the slides fully closed when the idle screw is fully backed off. I use the little red pipe from the top of the WD40 can and it's always worked spot on for me. Not sure which carbs you're working on but none I've ever worked on have a master as a bench mark. Maybe that's on the PD's as I've never worked on them.
« Last Edit: March 14, 2023, 03:56:40 PM by Nurse Julie »
Re: Carb bench sync
« Reply #2 on: March 14, 2023, 03:58:48 PM »
Thanks Julie! It’s the infamous PD carbs off the 550. I was going to use the vernier depth gauge which is a 16th”
1978 Honda CB550K3.
Re: Carb bench sync
« Reply #3 on: March 14, 2023, 04:20:34 PM »
You are correct Johnny, the dreaded PD carbs do indeed have a master carb which is the one you sync them all too.
Re: Carb bench sync
« Reply #4 on: March 14, 2023, 05:47:46 PM »
Cheers Ken! Synced and ready for fitting. New pilots fitted replaced 42’s for 45’s not expecting them to make a lot of difference but a move in the right direction.
1978 Honda CB550K3.
