Author Topic: 400 carb slider adjustment question need to check ?  (Read 1626 times)
« on: March 27, 2023, 11:55:50 AM »
I'm currently cleaning up my set of spare carbs for my 400 and have found a part I never noticed previously.
There are two solid dowels between the carb pairs  - can't find it in the parts book - anyone know the part number please?
« Last Edit: March 30, 2023, 09:06:03 PM by McCabe-Thiele (Ted) »
Re: 400 carb cleaning - missing part question ?
« Reply #1 on: March 27, 2023, 12:04:26 PM »
Ted, are you referring to the short peg that the throttle return spring hooks on? If so I don’t think there is a part no?
« Last Edit: March 27, 2023, 12:26:13 PM by Sesman »
« Reply #2 on: March 27, 2023, 12:11:31 PM »
It was never available mate, i have a box of assorted 400 bits and will look on saturday for you but dont know if there is one. I think the 500 is same part.
« Reply #3 on: March 27, 2023, 12:55:56 PM »
Its not that part it is a dowel that sits between carbs 1-2 & 3-4 towards the rear of the body - some sort of alignment spacer. One of mine is missing. TBH I don't think the carbs on my 400 have either of them.
« Reply #4 on: March 27, 2023, 12:57:14 PM »
If you happen to have one brilliant - thanks Bryan.
Update:- It appears there are plenty of Dowels on flea-bay in SS 10 mm x 6mm reasonably cheap - just plain with no center groove. If I can find an original would be better.
« Last Edit: March 28, 2023, 04:55:50 AM by McCabe-Thiele (Ted) »
Offline Matt_Harrington
« Reply #5 on: March 28, 2023, 09:57:55 AM »
Ted, is it possible to photo this area? I'm rebuilding a set and don't seem to remember seeing them before they were stripped....
« Reply #6 on: March 28, 2023, 10:09:22 AM »
quick find,
type in CMSNL CB400F Carb and look at part number 17 which is the spring Matt, I think Ted means the bit that sits at the bottom of it to attatch the spring to, I had nothing else on my carbs when I dod those. Cabt really think of anything else that refers to a small round connector either........
https://images.cmsnl.com/img/partslists/honda-cb400f-super-sport-400-four-1975-cb400fk0-usa-carburetor_bighu0235e7019_a936.gif
« Reply #7 on: March 28, 2023, 10:11:19 AM »
He reckons not in an earlier post.
« Reply #8 on: March 28, 2023, 10:14:13 AM »
MOrning Phil,
dunno what else it can be, Ted you described it as a barrel of steel 10mm x 6mm with a groove in it, there is only one, I'm sure.
Could we employ the use of a 400 anorak please?......anyone?
Offline Multiman
« Reply #9 on: March 28, 2023, 10:24:33 AM »
Having stripped and rebuilt my 400 carbs last week the only thing I can think of is the spring peg between 2&3. As had been said it is in the parts book diagram but doesn’t have a part number and there’s only one of ‘em. If it’s not that component I’m mystified.
« Reply #10 on: March 28, 2023, 10:27:55 AM »
I like the way you came forward as an anorak Tim ;D
Arent you supposed to be doing your 1 day a week today and working?
« Reply #11 on: March 28, 2023, 10:32:13 AM »
quick find,
OK, when this sodding rain stops, I'm off to the shed to 'ave a shufty!
Offline Multiman
« Reply #12 on: March 28, 2023, 10:41:39 AM »
Yes thank you Roo. Up bright and early for my Cardiff gig.
It’s a bit damp over here so the anorak has come in useful.
« Reply #13 on: March 28, 2023, 10:44:48 AM »
OOOsh, a wet Cardiff.......nasty! ;D
« Reply #14 on: March 28, 2023, 01:43:13 PM »
Steady! 💦😅
