Author Topic: 400 carb slider adjustment question need to check ?  (Read 1717 times)
Re: 400 carb cleaning - missing part question ?
« Reply #15 on: March 28, 2023, 01:53:02 PM »
Ooops, bout that ;D ;D
« Reply #16 on: March 28, 2023, 02:15:31 PM »
On reflection I think the suggestions about where the spring sits accounts for why I only have one dowel - that's logical - it explains the groove  as well thanks Philip, Multiman & Mr Spock . My Bad.
As a poor excuse I dismantled, numbered & individually boxed the parts about 5 months ago just started assembly last week. Currently using the US cleaner for each carb as I put them together.Duh
« Last Edit: March 28, 2023, 02:33:13 PM by McCabe-Thiele (Ted) »
« Reply #17 on: March 28, 2023, 03:06:55 PM »
So is the spring dowel missing or not Ted? If you thought there were 3 of them I can see why you'd think 2 have gone missing but are you still missing the original between 2 and 3. TBH it looks to be the same part as the 500/550 carbs.
« Reply #18 on: March 28, 2023, 03:27:11 PM »
I have just the one - it's the center spring dowel - so all is well.
« Reply #19 on: March 28, 2023, 03:56:12 PM »
That’s the chap,Ted. Short solid barrel, waisted in the middle for the spring👍 The item below ‘17’ on the CMNSL fiche as identified by Roo.
« Reply #20 on: March 28, 2023, 03:57:15 PM »
Yer welcome 8)
I got summut right for a change, get me ;D ;D ;D
« Reply #21 on: March 28, 2023, 04:30:27 PM »
Offline Matt_Harrington
« Reply #22 on: March 28, 2023, 05:04:34 PM »
Just found mine - so thanks for the heads up as it would have been a pain to take 'em all apart again....
« Reply #23 on: March 28, 2023, 05:30:05 PM »
Yes that's the part!
« Reply #24 on: March 28, 2023, 06:05:32 PM »
Mine are now all back together - now comes the fun part of setting them up!
« Reply #25 on: March 28, 2023, 06:09:04 PM »
You still thinking on bobbing over to have a gander at the 400 engine this week Matt?
« Reply #26 on: March 28, 2023, 06:12:30 PM »
Actually, tomorrow is free - OK? PM me details....
Re: 400 carb slider adjustment question/check
« Reply #27 on: March 30, 2023, 06:26:55 PM »
I clearly have the memory of a Goldfish when it comes to putting my carbs back in place on the manifold/frame.
Is it correct to set the height of the sliders using the screws in the picture below to adjust them as needed - last time I used a small drill bit shaft iirc.
400 slide adjusters by Macabe Thiele, on Flickr
« Last Edit: March 30, 2023, 09:05:06 PM by McCabe-Thiele (Ted) »
Offline Multiman
Re: 400 carb slider adjustment question need to check ?
« Reply #28 on: March 30, 2023, 09:41:39 PM »
Yes, those are the screws to set the slider heights.
« Reply #29 on: March 31, 2023, 09:08:36 AM »
Thanks I just can't remember using them when I first rebuilt the carbs on my 400 before Covid - in my head I thought I used the screws between the carb links.
One of the float pillar tips was in poor condition so this spare set will eventually replace them. Keeping busy tinkering before I resume work on the 500 forks.
