Author Topic: 400/4 adjuster  (Read 653 times)
Offline Matt_Harrington
400/4 adjuster
« on: April 03, 2023, 02:53:10 PM »
You will ssee in the photo that my spare set of carbs has an adjuster that is just too long. (one next to it is, I believe the correct one - robbed from another bike of mine!)
Anyone got a spare short one? Oh and yes, which bike takes the longer one?
Re: 400/4 adjuster
« Reply #1 on: April 03, 2023, 03:14:13 PM »
One on the right looks like the one fitted to the 500/550 bank of carbs.
The one on the left TBH looks exactly like the ones fitted to the R/H switchgear of the 500 and 750 for holding the throttle open.
I might have an old one lying around, they were originally chromed but it's mostly wore off now, can you measure it, it's a 5mm screw but how long from under the head to the end of the threads.
Re: 400/4 adjuster
« Reply #2 on: April 03, 2023, 03:31:26 PM »
Just cheked Matt and they are not the same, the one I have has a large shoulder on it and not that much thread. One on the right is definitely off the 500/550. Ted may have one, think he's got a broken set of 400 carbs.
Re: 400/4 adjuster
« Reply #3 on: April 03, 2023, 03:41:33 PM »
Try Steve he will give you a price for the bit you want see item in picture F140 in carb section.
.https://www.400fourbits.co.uk/#fuel
« Last Edit: April 03, 2023, 03:43:34 PM by McCabe-Thiele (Ted) »
Re: 400/4 adjuster
« Reply #4 on: April 04, 2023, 10:01:12 AM »
Cheers Ted. Sent Steve an email....
Re: 400/4 adjuster
« Reply #5 on: April 07, 2023, 06:19:32 PM »
Steve is sending me the part together with another item I need. Checked Roo's 550 and the bigger adjuster is the same as the 550 and the smaller is as per 400....
