Author Topic: Rubber Mounting Rubbers - 84705-292-000  (Read 1323 times)
Offline philward
« on: April 24, 2023, 11:58:50 AM »
The above mounting rubber grommets are perished at various locations on my 350k0 project. Has anyone got any decent ones I can buy please? I need 6.
DS is out of stock at the moment and want £4 odd each anyway.
Thanks in advance
Offline philward
Re: Rubber Mounting Rubbers - 84705-292-000
« Reply #1 on: April 24, 2023, 12:06:13 PM »
Also need decent solenoid cable rubber (mounting stud) covers if anyone has any of them to sell
« Reply #2 on: April 24, 2023, 02:29:34 PM »
I wondered what those were Phil so I looked them up and they are used on loads of bikes, the 500 uses them to mount the number plate holder to the rear mudguard for instance. What's odd though is that the Cb550F, which uses the same number plate bracket isn't shown on the list as using them, which I thought was odd so I looked up what they showed as listed and they have what looks to me the be the exact same rubber but with a different part number 80101-283-000.
Have yours got dowels in the centre? The 550 part may be the same but it may be slightly thicker for better cushioning, DS has 3 of those in stock. I did find a load of them the other day but I don't know yet whether they are spares or off my rebuild, I know my number plate bracket has them missing for instance. I doubt I have 6 spare either way. I'll have a look around, it's a very common part.
Offline philward
« Reply #3 on: April 24, 2023, 02:51:05 PM »
Sorry Ken, should have referenced the part number to the lamp/number plate mount. Mine has the dowels in the middle
« Reply #4 on: April 24, 2023, 03:10:19 PM »
Yeah the 500 doesn't use dowels, the bolt are shouldered most of the way down to act as the dowels. I'll see what I can find Phil.
What's the solenoid part number, might be used on other models.
Offline philward
« Reply #5 on: April 24, 2023, 03:51:11 PM »
Solenoid part number is 35850286017 and terminal rubber cover is 32411-253-000. I can get them on special order from DS - going to put an order for engine bits next month anyway
« Reply #6 on: April 24, 2023, 04:26:45 PM »
The rubber cover looks to be the same used on the end of the starter motor cable, might have one of those.
Can you measure the mounting rubbers Phil, I have some that have no dowels in (most likely mine off the rear number plate bracket) and some that do have a dowel but the dowel is longer than the rubber so it sticks out a little from it. No idea where they came from but I have been stripping some USA parts so they could have come from those. How thick are they and how long is the dowel.
« Reply #7 on: April 24, 2023, 05:43:11 PM »
Im sure i bought a bag of 10 or more on ebay that looked similar, probably slightly different sizes but could be made to work. I will see if i can find them again
« Reply #8 on: April 24, 2023, 05:53:52 PM »
Try ebay item 403821508710 dont ask for link i cant do those on this dumfone!.
Look similar and cheap enough for a punt
Offline philward
« Reply #10 on: April 24, 2023, 06:08:06 PM »
13mm wide, 8.5mm thick and hole is 8mm - thanks
Offline philward
Offline philward
« Reply #12 on: April 24, 2023, 06:09:22 PM »
Thanks Bryan
« Reply #13 on: April 24, 2023, 06:09:47 PM »
I don't think those fairing ones fit Roo iirc they are too small.
Pretty sure I bought some for my 400 a couple of years ago - could be mistaken holes are 6mm?
« Last Edit: April 24, 2023, 07:27:34 PM by McCabe-Thiele (Ted) »
« Reply #14 on: April 24, 2023, 07:41:29 PM »
That was Bryan’s link Ted not mine buddy
